HELP! Mirrors and Window Control Reversed, among other things
04-29-2015, 12:13 PM | #1 |
Libertarian
132
Rep 1,577
[Yes, I did a search for answers]
Ok, long story short, I had to replace my FRM3 after having other issues. The net is a low-battery start fried my old FRM3. I bought a new FRM and plugged it in. My hi-beams and turn signals are functional again! YEAH. I have BMWhat app, and a bluetooth adapter for BMWhat. I am now able to communicate with the new FRM3. BUT - There are a few things still wrong after plugging the new FRM in. Here's what is still wrong and I can't seem to fix them: 1) The Angel Eyes flicker. 2) The windows switches are reversed. If I push the button that used to lower the drivers window, it now lowers the PASSENGER window and vice-versa. 3) I have a Coupe - the windows used to lower 1/4" or whatever because they are frameless doors. It does not do that any more. I have already done the reset of the windows by holding the button down for 10-12 seconds. 4) The mirror switches are also reversed. If I flip the switch to the left to adjust the driver's side, it adjusts the passenger side mirror. Also up/down = left/right and left/right = up/down. Very confusing, right? 5) When in reverse, the auto-dipping lowers my DRIVERS side mirror, not the passenger side like it did before. 6) The red car on a lift warning light in the instrument panel is still there. This may be because of some other module - I have to look into that more. Do I need to have the BMW dealer fix these issues, or can it be done with INPA on a Win7 laptop? I would hate to take it to the BMW dealer and let them keep it hostage for days...
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
04-29-2015, 12:24 PM | #3 | |
Libertarian
132
Rep 1,577
I think the Angel Eye flickering is just a setting I need to change.
04-29-2015, 01:19 PM | #4 | |
533
Rep 2,872
04-29-2015, 01:57 PM | #6 |
Rep 11
Could that unit have come from a euro car? It's a stretch and doesn't explain the up/down switch, but thought id' rule that out.
07 335i 01 540i (heart condition) |
04-29-2015, 05:08 PM | #7 |
Libertarian
132
Rep 1,577
I'm getting it coded this Saturday -that should solve it all... In the meantime it's tolerable. I was hoping I could do it all with Bmwhat, but it is limited in capability for this.
04-29-2015, 11:05 PM | #8 |
136
Rep 581
Drives: 2010 AW 328 [Sold]
I don't know but the explanation makes me think it was from a right hand drive car since everything is reversed.
Hope it gets sorted soon! |
04-30-2015, 11:38 AM | #9 |
No 55mph
1622
Rep 8,476
New FRM needs coded to your car. Can't do what is needed with BMWHat...
You will either need to use NCSEXpert/INPA or take to dealer for big $$
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
04-30-2015, 11:59 AM | #10 |
687
Rep 2,770
Probably came from an e90 since the window down on open function is unique to E92/93 with our frameless windows.
Like others have said, you need to get the new FRM coded to your car with all the proper VO codes. That should solve all your issues. Without the right VO programmed the FRM has no idea it is in your car.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
04-18-2019, 12:53 PM | #11 |
Rep 1
Reversed window and mirror Function
Hi
I would like to ask you if you were able to resolve the issues listed in your post issue # 2,4, and 5. I purchased a 2011 328i coupe where I have the same issues as you do. it only impacts the window's and mirror's. I just wonder if you are able to share the solution if you found one. Note I purchased another switch and it made no difference. Thanks |
01-13-2020, 03:14 PM | #12 | |
Rep 4
You still need to code your VIN number into the FRM module.
See: https://bimmerscan.com/wp-content/up.../B012016-1.pdf The FRM module is covered by 100K miles/10 years warranty. It could be damaged when the battery is low or disconnected. This is a very popular problem. My power window/mirror left and right control button were reversed. If your car is not covered by warranty. You can still go to ebay. They have FRM repair service for around $150. You just need to mail your FRM to them. https://www.ebay.com/sch/i.html?_fro...epair&_sacat=0 Good luck! Quote:
04-18-2021, 07:14 PM | #15 |
42
Rep 87
This happened to me when i resurrected my frm module in my 2011 e90 (lci). As simply as possible (emphasis on SIMPLY), when i restored my frm so it would communicate with the car again, I used a settings file that i found online that was NOT for my car. Now, on to how i fixed it. I did these things in order of easiest to hardest in terms of difficulty. I dont remember what exactly fixed it, but ut was definitely one of these 3 things.
Note: if your battery voltage is too low at any point, your frm module will be bricked. Do all the coding with the car running. If you try to flash the frm with car running it will start shaking and eventually shut off by itself. Whatever you do, do not touch anything until the flash is done, or you can brick it. See step 3 for how to unbrick in super simple terms. 1. Write the VO from YOUR CAS module to YOUR frm module (mine was called NFRM in ncsexpert). I believe you need to do it using your factory coding profile, but you can try doing it with your custom coding profile too, it wont hurt anything. Now, you my be able to just let the car go to sleep and when you come back everything is working correctly, if not... 2. Using your factory coding profile, do the same thing you always do when you code anything, to get your vin and vo to appear in ncsexpert. Now, READ your nfrm module by either selecting it and clicking ‘read’ if your profile has that feature, or otherwise just run the READ job ‘codieren liesen’ or whatever. The only reason you are doing this is to get ncsexpert to select the correct coding files using your VO. Basically, sometimes after your frm is brought back to life, for some reason that I haven’t figured out yet, ncsexpert will choose the wrong coding files. When you read from your nfrm it will somehow figure out that its using the wrong coding files, and will change the files used to code, to the correct ones based on the VO stored in your frm module. After this step, just run the ‘write’ or ‘code’ job that you always run to code your car. Again, i forget what its called because its in german ‘schrieben’?? Turn off car, let it go to sleep which takes about 16 minutes, then come back and see if problem is fixed. If neither of those work then... 3. Use winkfp to flash your frm modules ‘firmware’ or whatever you want to call it. Basically you will use the zb number written on your frm module on the sticker, to flash your frm modules firmware (EEPROM, basically the firmware tells your frm module what car it is in, so it ‘knows’ which features should be enabled/disabled when you code it in ncsexpert. Look up guides on how to do this, and do it in comfort mode if possible, I believe it is safer, but worse thing that can happen is you brick the module, which would then require you to flash the firmware on the bench ie using a eeprom programmer like xprog. After flashing the frm which i believe takes around 5-10 minutes, you may walk away and let the car sleep. If when you come back and it still doesnt work, repeat what you did in step 1 and step 2 using ncsexpert to write the correct coding parameters for your car based on the VO. If none of these steps worked, I don’t know what to tell you. Maybe your VO was modified in the past so its not correct, maybe its something else. If your lights are still blinking/flashing you have to reset short circuit counters in your frm module using tool32. (I think). Note: this is all assuming that you did not upgrade or downgrade to another frm module that your car did not come with. Ie changing from frm1 to frm3 because you wanted welcome lights or whatever. Last edited by KhaosKid; 04-18-2021 at 07:21 PM.. |
04-19-2021, 04:37 PM | #16 |
Rep 56
this all started because i wanted electric folding mirrors, so i sourced some from a RHD car, my car is left hand drive. now i have everything working except for the fact the the directions on the mirror controls are mixed up. the windows are all working as should be, with correct button corresponding to correct window. today i went into inpa and checked the switch. and in inpa everything checks out. left is left, right is right etc etc... but for some reason my mirrors dont do what the button says. so i press down it moves right, up moves left. so im wondering if its the frm or if its the mirrors themselves being from a RHD car. what doesnt make sense is that Rhd or Lhd left is left, right is right. so i dont see what how this could affect it.... thinking i might swap the mirrors over, and see if that fixes the issue
04-28-2021, 06:26 PM | #18 |
43
Rep 186
Drives: 07 E92 335i 6MT
Carlosjpt , were you able to figure this out? I've got the exact same issue with my LH mirror. I'm thinking it may have come from a RHD car.
2007 E92 335i BSM/Saddle 6MT
ZSP / ZPP / ZCW LC818 / PSS (FR) / PS4S (RR) Dynavin N6 OEM M3 Carbon Roof / OEM M3 Mirrors |
05-04-2021, 07:14 PM | #19 | |
Rep 56
not yet, but this week i will be swapping the mirrors over to see what happens.... in my mind it must be the mirrors. will update shortly |
05-07-2021, 08:32 AM | #20 | |
43
Rep 186
My LHD car came equipped with: LH - "LLL" RH - "LLR" I purchased (unknowingly): LH - "RLL" (this one was wonky) RH - "LLR" (this one worked fine) This leads me to strongly believe the first letter designates LHD or RHD, while the last is LH or RH. I have no idea what the middle letter could mean.
05-30-2021, 07:43 AM | #21 |
Rep 5
Interesting. I am looking at replacing my water damaged DME (cant communicate with it so cant clone it I think) with a matching DME, CAS unit and key. I see an ideal one on ebay other than its LHD and my car is RHD. I am as yet unexperienced with coding these BMW units but I'll learn it, anyone used a LHD DME with a RHD car and noted what needed to be modified?
05-30-2021, 09:24 AM | #22 | |
654
Rep 1,893
But you will certainly have to code the replacement modules and you may have to flash them. The first issue of concern is that the VO in your replacement CAS is very unlikely to match your vehicle's options so you'll have to read the original VO from the NFRM (where a second copy is stored) using NCSExpert, write it to the replacement CAS using and then default code (code using parameters specified in the VO rather than an external file) both CAS and DME. I wouldn't be surprised if the both modules needed to be flashed (program update) as well. You don't necessarily know when the replacement modules were last updated or if they were flashed with files appropriate for your option level and location. Flashing requires the use of WinKFP, which is not any more complicated than coding with NCSExpert. However, NCSExpert cannot permanently injure anything while WinKFP, if you are really uninformed or careless about its use, can destroy a module. So yes, you'll have to do a bit of reading up on the use of BMW Standard Tools. EDIT: The fact that you cannot connect to the original DME via OBDII probably does mean it cannot be cloned but that is not a given. If your DME is an EDC17, with a tricore processor, probably not. But you should contact a service advertising cloning expertise and ask. Last edited by dpaul; 05-30-2021 at 09:37 AM.. |
