System too lean. Cracked chargepipe?
04-28-2015, 09:46 PM | #1 |
352
Rep 2,050
Hello guys, I recently had my chargepipe pop where it connects to the throttle body. It also broke at the mouth and threw the c clip off. I ordered an ER chargepipe but it's taking time to arrive. In the meantime I secured it back in place and I've been driving the car to work granny status. It's still leaking of course.
Now my car is throwing system too lean codes. Bank 1 and 2. Doesn't make sense since the n54 doesn't have a MAF. I was expecting 30ff codes. I'm hoping it's not anything else. Someone educate me . Thanks
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
04-29-2015, 08:28 AM | #3 |
562
Rep 3,625
I was getting fuel mixture codes when the vacuum line going from one the diverter valves to manifold came loose. I couldn't hit 12 psi where I would normally hit 18-19 psi and no 30ff code.
04-29-2015, 09:24 AM | #4 | |
352
Rep 2,050
I was getting mixture codes before that tho after running e85
'10 e92 N54
04-29-2015, 09:34 AM | #5 |
562
Rep 3,625
04-29-2015, 11:48 AM | #6 |
82
Rep 405
Exactly the same happened to me last week and still waiting for a vrsf one (should arrive tomorrow). I thought about doing the same as you for the 3 miles to and from work but in the end didn't want to risk it.
Afraid I can't help on the codes. Not even sure which ones mine has thrown. But I'd fix the problem first, reset the codes (?), then start from there and see if you have new warnings after that. Speaking of which, not sure how I'm going to reset the codes/check engine light on mine tomorrow... |
04-29-2015, 12:38 PM | #7 |
BimmerPost Supporting Vendor
24199
Rep 190,807
It is probably caused by the cracked charge pipe. You should not be having any issues once you receive the new one.
04-29-2015, 12:49 PM | #8 | |
352
Rep 2,050
'10 e92 N54
04-30-2015, 08:12 PM | #9 | |
352
Rep 2,050
'10 e92 N54
05-01-2015, 07:19 AM | #10 | |
562
Rep 3,625
I'm sure this could cause a lean condition. |
