N54 - Safe to do thermostat without replacing water pump?
04-27-2015, 08:08 PM | #1 |
432
Rep 1,602
Getting the thermostat code and the car is intermittently running 5-10 degrees too cool. Must be a German car thing - my wife's thermostat in her Audi went out way sooner than expected as well.
Regardless, I'd rather not blow $480 to fix an $80 problem. Of course I have no idea when (or if) the water pump has been replaced previously. The laziness in me says do it all at once, so I don't have to dig in there again. The cheap ass in me says "why blow $400 to replace a perfectly good pump?" Any thoughts? |
04-27-2015, 08:21 PM | #2 |
22
Rep 175
Well why don't you fire up the pump and find out? Start the pump without starting the engine. The pump should not make any noise other than from circulating the water.
2011 335i xdrive Jerez Black Limited Edition Manual
04-27-2015, 08:26 PM | #3 |
1645
Rep 2,494
Granted, I'm driving an N52, but... my car presented with the same symptoms and I didn't change my waterpump. Car threw code for thermostat, so I started monitoring coolant temp via hidden menu and noted that it was taking longer to get up to temperature and then settling at a lower average temperature when cruising.
I replaced thermostat, flushed with new coolant mixture then ran the bleeding process. I've put about 4,000 miles on it since then and so far so good.
04-27-2015, 08:34 PM | #5 |
1645
Rep 2,494
I would just do the coolant bleed procedure if you want to verify waterpump function. Key in ignition, car on but engine not started - turn heat to max then hold down accelerator for ~30 sec. You'll hear the water pump kick on and coolant start cycling. Kinda sounds like a dishwasher, runs for 12 mins.
04-27-2015, 09:22 PM | #6 |
2032
Rep 8,339
Probably but while your there why not do it as preventative maintenance. these pumps typically go after 75,000 miles. mine was a hero with 200,000 when it blew. part is $390 @ getbmwparts. Saves you the cost of the tow and gives you peace of mind.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
04-27-2015, 10:21 PM | #7 |
91
Rep 610
this. mine went at 108 and i knew i was on borrowed time. kept putting off the water pump, despite what i read on here about these things failing at 75k. long story short, car stranded me, so i got to pay a tow bill plus the replacement parts. yay.
04-27-2015, 10:55 PM | #8 |
228
Rep 1,045
Lots of water pumps fail in the 50K-70K interval; some fail sooner, some go 120K, and you real one lucky soul's 200K!
So depending upon your car's mileage, you are placing a statistical bet. Ask yourself, "How much extra money do I have to 're-spend' on labor by putting off the water pump and not doing it at the same time as the thermostat replacement?" |
04-27-2015, 11:31 PM | #9 |
2032
Rep 8,339
labor and tow too not to mention the inconvenience of being stranded. I got stuck on the Florida turnpike for 2 hours.
04-28-2015, 12:53 AM | #10 | |
19
Rep 88
04-28-2015, 03:29 AM | #11 |
DIE ANTWOORD
68
Rep 640
Would changing the water pump and keeping the old pump as a spare make sense?
Whith the pump out and no hurry maybe you can overhaul it if something is out of spec? There should be nothing special inside
King of the road says you move to slow
04-28-2015, 06:43 AM | #12 |
317
Rep 1,735
No the reason why pumps fail is because the seal breaks leaking water into the circuit. Replace pump now and not worry about it for another 80k
04-28-2015, 07:29 AM | #13 |
22
Rep 175
Neither. Water pump can be run with key in acc mode and push on the gas pedal for about 20 seconds. This will put the pump in coolant recirculation mode, and is intended to cycle coolant after coolant replacement to get the air out of the system without running the engine so the coolant will not get too hot in the process. Beauty of an electric pump.
04-28-2015, 06:24 PM | #14 |
866
Rep 5,450
I would do them both, if it is an 07 with original pump it is a ticking time bomb and you are doing all the labor once you have the thermostat out, the pump is easy, if your paying someone, you will pay labor twice if you wait. Only way to tell is get the part number off the pump and see if it is one of the original problem part numbers or the new updated pump that has not been change since about 2012.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
04-29-2015, 12:54 AM | #15 |
3973
Rep 7,215
no that is not why they fail. I opened mine as have others - bone dry inside. Something inside the circuit was made cheaply and it just burns out. as far as I could tell, the inside of the pump was immaculate.
05-03-2015, 07:25 PM | #16 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
It depends on how many miles you have on the car? If you are between 75,000 and 110,000 miles then you should replace both the thermostat and the water pump. Probably 1% of all e90 BMW's will make past 110k with the original water pump. If some some assurances on making the next water pump last a little longer, run AMSOIL coolant and cut it with 50% distilled water and then add 8 ounces of AMSOIL coolant booster to each gallon of your mixture of distilled water and AMSOIL coolant.
Make sure you do a complete flush of the old fluid before adding you new coolant. You can use distilled water; some add a detergent. Prestone makes one. You can make the DIY easier if you take out the fan and inner cooler. That will give you more room to work with. There is a great DIY on the Bav Auto site. |
05-04-2015, 10:01 PM | #17 |
180
Rep 545
I guess it's time to start ordering parts. My thermostat is dead and at 110k miles I believe I'm on the stock pump.
- 335is DCT - 10.5 @ 132 and dropping!
05-05-2015, 08:55 AM | #18 |
3973
Rep 7,215
I must have a unicorn - 110k and going strong. I changed the error codes for the pump to trigger a CEL, i want to know if they will give me any advanced warning of pump failure.
Even my wife' s car, which was not well maintained, lasted to 90k. |
05-05-2015, 09:15 AM | #19 | |
466
Rep 1,980
Mine is a 2007 and it was replaced with 50k miles last year (so 50k / 7 years). It has 64 miles today. |
01-31-2019, 08:59 AM | #21 | |
2659
Rep 6,290
Yeah I know old thread but I know you're still active so I wanted to ask haha. |
01-31-2019, 09:50 AM | #22 |
3973
Rep 7,215
It's not coding. I modified the flash tune. Maybe you could do it with a custom MHD file, but you'd have to know how to edit the binary to turn *on* the CEL.
