Getting New Tires, Can I go Wider than the BMW standard size?
04-27-2015, 08:04 AM | #1 |
28
Rep 205
Have an e92 2008 coupe, have 225 in the front and 245 in the back. The regular standard.
But I'm wondering is it possible to have wider/bigger tires without it affecting the car? Wonder if anyone has ever done this. |
04-27-2015, 08:06 AM | #2 |
7478
Rep 10,120
04-27-2015, 08:13 AM | #3 |
2032
Rep 8,339
uh. yeah. there's a search function. lol. most people go up to 235 or 245 front, 275 rear. that's normal.im going to 245 front, 305 rear with some modification.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
04-27-2015, 08:25 AM | #6 |
28
Rep 205
No it's not AWD, it's RWD 335i, I have the stock OEM rims that come with the 335. The thick star looking ones.
These... Is it possible? What sizes should I get? Need help, I don't know anything about Tires. |
04-27-2015, 08:46 AM | #9 |
2032
Rep 8,339
Front is 18x8 and ready is 18x8.5. You can look on tirerack website to get suggestions based on your car. Where are you located? What's most important? Mileage, performance, quietness, ride, etc. That would,point you towards a tire type.
04-27-2015, 08:55 AM | #11 |
2032
Rep 8,339
You can go bigger but you'll need bigger wheels.
04-27-2015, 08:59 AM | #12 | |
2032
Rep 8,339
04-27-2015, 09:06 AM | #13 | |
28
Rep 205
But I just want a bigger and wider size that I had previously. Just trying to make sure if I do, I get a bigger size that doesn't compromise the car. |
04-27-2015, 09:14 AM | #14 | ||
2032
Rep 8,339
04-27-2015, 09:23 AM | #15 | |
28
Rep 205
Is their an absolute proposed larger size for my OEM rims? Thats what I need most, plan to go in today. |
04-27-2015, 09:30 AM | #16 |
4490
Rep 10,473
The widest ones for your OEM rims would be a 255/35/18 in the back, the pilot super sport are very wide so a 255 in michelins is almost like a 265-275 hankook tire.
If you go for a 265 in the rear it will be too wide for wheel and will bulge like on an SUV and under really hard cornering the sidewall can buckle. for the front a 225 is perfect as well but you have a little more room so for front you can go 235, but then because of the aspect ratio your front tire will either be taller or shorter than the rear. I had these tires on oem wheels on my 335d. |
04-27-2015, 09:42 AM | #17 |
2032
Rep 8,339
tirerack says 265 will fit an 8.5 wide rear on the Michelin Pilot Super Sport tires. I've seen 20s sometimes but 19 seems to be the most often upgrade. fits the car. 19x8.5 front, 19x9.5 rear. that's what I currently have.
04-27-2015, 09:48 AM | #18 |
39
Rep 115
I'm running a 255 35/18 squared setup on an 8.5" wide wheel. No rubbing up front. 35mm offset.
04-27-2015, 09:50 AM | #19 | |
28
Rep 205
255 is the recommended size rears for BMW right? How are people putting 265 or even 275 on the rear and getting away with it? |
04-27-2015, 09:55 AM | #20 | ||
2032
Rep 8,339
do you know what the numbers mean in a tire size?
04-27-2015, 10:03 AM | #21 |
2032
Rep 8,339
first number is tire width in milimeters. second is profile. This means the sidewall from rim to tread is this percentage of the width. For example. a 200/40-18 tire would be 200 milimeters wide, or about 8 inches. the sidewall would be 80 milimeters, or about 3.4 inches, and the overall diameter would be 24.8 inches. 3.4 + 3.4+ 18. you need to count the sidewall width twice for top and bottom. so a 235/35-19 is about the same outer diameter as a 275/30-19. both about 26" . I'm my case 25.5" front, 25.6" rear.
04-27-2015, 10:04 AM | #22 | |
28
Rep 205
All I know is I've always gotten 225 in the Front and 255 in the back this whole time. The exact sizes BMW puts on them. What the tire guys have always said. So you're saying that 265 will be okay for my OEM rims? And 235 for the front is okay aswell? Bumping it up 10 on each pair - I should have no issues? That's all I'm trying to make sure. |
