04-25-2015, 07:24 PM | #1 |
Rep 36
Chrome Exhaust Tips Help!!!!
Went all around town looking for a muffler shop to install the M Performance Chrome Exhaust Tips with the pipe adapters to the stock exhaust. From what I've read on the Performance Parts installation guide it looks fairly simple, just cut off a section of the stock pipes, attach the adaptors and add the chrome tips. These shops were quoting me $100+ and saying its a very difficult job or "it can't be done with clamps it must be welded."
This is really frustrating and frankly I believe it shouldn't cost more than $20. What are your opinions on this situation?? I'm thinking of attempting to do it myself but the "cutting off a portion of the stock pipes," doesn't seem like it may be a simple task to an amateur. Please give me suggestions!! |
04-25-2015, 11:09 PM | #3 |
127
Rep 765
Holy cow, I was thinking the same - quick cheap job and just swap tips to put chrome ones on mine. But these things are welded on?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
04-25-2015, 11:19 PM | #4 |
Rep 36
from what i read on the performance parts installation guide, it said nothing about welding. simply cut the stock pipes and clamp on the adapters. i think the guy i talked to was just trying to make it sound complicated to charge more. although now I am questioning whether it needs to be welded on as well...
04-26-2015, 01:05 AM | #5 |
16
Rep 98
Definitely no welding needed, just use the clamps to upsize the original pipes to fit the chrome ones. The only reason you actually need to cut an inch or so of the original is so the clamps can be inconspicuous when used, you could just try without cutting the pipes to see how it looks but guess they would stick out to far.before fitting my MPE dealer had just put the chrome ones on mine.
Mind you guess a couple of spot weld directly onto the original would work too |
04-26-2015, 10:06 AM | #6 |
127
Rep 765
Makes sense now, but I thought that BMW would just make tips that fit, instead of needing modification. Was their original intent that the chrome tips only go on the MPE then? Hence the need for modification to make it fit a standard M235?
Seems odd for BMW who created a complete aftermarket for their own cars (MP) to still require modification to make the stuff fit.
04-26-2015, 11:07 AM | #7 | |
Rep 36
anyways, still kind of stuck on how difficult it will be to cut the stock exhaust myself. no idea what kind of machinery i need, how expensive it is, and if i am able to cut the pipes while the stock exhaust is still on the car or if it has to be removed before any changes are made. ugh... |
04-26-2015, 12:25 PM | #8 | |
1399
Rep 5,262
http://www.2addicts.com/forums/showt...hlight=Install |
