Steering wheel paddles help
04-20-2015, 06:18 AM | #1 |
691
Rep 4,263
Guys I installed a MSport wheel with paddles sometime ago but have never managed to get the paddles to work. Now this did not bother me as I always manually changed using the gearstick anyway.
However , the more I have thought about it , the more it is beginning to bug me. Why don't they work is it a coding issue ?
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
04-20-2015, 06:31 AM | #2 |
162
Rep 2,399
what SE steering wheel did you have first? the big ugly weird shape one or the one which looks really similar to m sport.
i think it may be your MFSW buttons. if your using M Sport ones it might not work as this is what happened with M3 wheel when i put it in mine. others will be able to confirm though for defo soon. |
04-20-2015, 06:37 AM | #3 |
691
Rep 4,263
Hey Raj cant even remember what my old SE one looked like!
04-20-2015, 07:48 AM | #6 |
691
Rep 4,263
All buttons work mate , volume up , down etc just the paddles dont work
04-20-2015, 09:27 AM | #9 |
691
Rep 4,263
04-20-2015, 09:27 AM | #10 |
691
Rep 4,263
OK will try that
04-20-2015, 09:54 AM | #11 |
448
Rep 3,312
Are they plugged in?
I know having changed the wheel in mine a couple of times as long as the everything is plugged in correctly they have worked fine (inc. SE push/pull paddles and DCT ones). As above if the buttons are from an M3 and has the M button in place then that will not work.
E92 335i / M3 Hybrid - The Build
04-20-2015, 10:59 AM | #12 |
691
Rep 4,263
Yeh all plugged in mate, maybe worth getting another set of paddles?
04-21-2015, 12:41 AM | #16 |
691
Rep 4,263
Yes mate they are the SE paddles , will swap the buttons over and see what happens , cheers.
04-21-2015, 05:59 PM | #17 |
337
Rep 1,661
Mark,
If you don't have any success: Is your M Sport wheel from a late 2010 onwards car? The paddles changed then from the push/pull to pull only, and the paddle electronics changed from just being a discrete switch to switches and pull-up resistors. This means that there are less wires to connect, although the plugs are the same. It could be that if the wheel is a late one, the wires just aren't there. Just guessing though Mike |
04-22-2015, 12:36 AM | #18 |
691
Rep 4,263
Hey Mike hows things ?
Will have a look over the weekend and get a shot of both wheels side by side
04-22-2015, 07:16 PM | #19 |
337
Rep 1,661
Still resisting the lure of the re-map!
Seem to spend more time towing with the dog carrier than solo these days, but it's more of a rush when I do drive solo. Went to mid-Wales with the caravan a fortnight ago. 27-ish to the gallon on the way towing. 30-ish to the gallon on the way back solo. Love some of those Welsh roads! Four days later, the reverse trip, with an overall of a more normal 33 to the gallon. My son is on his first season of rallying a Freelander (very grass roots!), with me screaming in the passenger seat as co-driver. No wonder I am going greyer! See you around sometime Mike |
