Need help: I-drive (CCC) crashes/reboots
04-15-2015, 08:55 AM | #1 |
16
Rep 301
Hey guys,
I'm looking for some help/guidance in troubleshooting some issues with my electronics which I fear are becoming more frequent. I have a 2007 328xi with DVD Nav (CCC) and Logic7. My battery was replaced by a BMW dealer a year ago. The issues:
My biggest concern is the I-drive issue... It seems the DVD drive is only about $150 on ebay, but I really don't know where to start for the I-drive. Thanks for any help! Last edited by AdamN52; 04-15-2015 at 09:15 AM.. |
04-15-2015, 01:31 PM | #3 | |
16
Rep 301
Since it's an 8yr old car I'd have a hard time justifying spending much more than the repair costs to upgrade it, y'know? |
04-28-2015, 08:17 PM | #4 |
35
Rep 1,068
You have 2 different issues from what it seems. I'd start with a new CCC radio to replace yours.. about 200$-400$ for a CCC radio. if you wanted to go CIC, then it's easily a $1000-1500$ investment.
Then, after a new radio is installed, see if you still have audio problems. If so, your logic 7 amp is on it's last leg. I've seen them here used on these forums from 250-500$ (for a new one). There are alternatives to using a logic 7 amp, involves a Technic Logic 7 harness and then allows you to add an aftermarket amp. (in all, probabably same as or more than the factory logic 7 amp) so all depends on your needs
2006 BMW 325xi E91 Wagon SGM
18" Fast Nemesis / Azentis Staggered Bilstein B12 w/E93 Eibach Pro Kit 2009 CIC Retrofit + Combox 6NR, 6NF, snap-in retrofit |
04-28-2015, 09:08 PM | #5 | |
16
Rep 301
I think my iDrive issue is related to the DVD drive failing. I just got my new laser in the mail, so I'm gonna repair the drive shortly and see if that helps. I do agree the amp is probably fucked. One channel is pretty crackly when I send out test tones in INPA. I'll try swapping the speakers around and see if it follow the channel or the speaker. |
04-28-2015, 09:31 PM | #6 |
38
Rep 555
Drives: E93 328i
I got the same issue as you with #2 and #3... so sad how a nice option we paid for stops functioning well like that when our cars aren't even 10+ years old
2007 E93 328i | Space Gray Coral Red | M-Tech Front Bumper w/ Carbon Fiber Splitters | BMW Performance Rear Bumper | BMW Performance Exhaust w/ Secondary Cat Delete | Injen Intake | HID Angel Eyes | M3 Trunk Lip Spoiler
04-28-2015, 10:13 PM | #7 | |
16
Rep 301
The DVD issue isn't too bad to fix it seems, but still a pain in the ass that it has to be fixed at all. I've seen older DVD/cd players that still work, but I suppose they don't sit outside all winter. Lol I read the DVD laser failing can cause the CCC to reset - all the devices are connected via optical network in a big loop. Apparently if a device isn't functioning well it can trigger the network to reboot in an attempt to fix it. Not sure if that's accurate, but I'm going to try the DVD repair first and report back. In any case it's clear the DVD drive needs repair for starters. Last edited by AdamN52; 04-29-2015 at 01:29 PM.. |
05-11-2015, 09:33 AM | #8 | |
124
Rep 5,627
Tom |
05-11-2015, 11:37 AM | #9 | |
16
Rep 301
That's interesting - strange that it would cause static like that. I've tried re-burning the disc, and I found I had more errors when I burned at full speed. I'm not sure that I still have my old OE disc around or not. I have my new laser now (not installed yet), but the nav and stereo have been working fine for like 2 weeks. I've been waiting to see it act up again before I replace it. Coincidentally it's been very warm here for about 2wks as well, so I wonder if it's related. |
