Lowering: Requires camber kit or not?
01-17-2006, 11:55 AM | #1 |
574
Rep 6,750
I'm assuming that the suspension geometry of the e90 gives the vehicle more negative camber when lowered (springs alone or coilovers). Can the camber simply be readjusted within stock parameters or does an aftermarket camber kit need to be added?
01-17-2006, 12:00 PM | #2 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
I think the e90 has adjustments for camber, but I'm not sure. I don't think camber adjustment is needed for a minimal drop, but couldn't hurt !
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
01-18-2006, 08:54 AM | #3 |
8
Rep 127
camber kits don't necessarily give back positive camber, they often use the centerline of the stock settings as their starting point. before you purchase, ask if the kit in question gives back positive camber
01-22-2006, 04:07 PM | #4 | |
Chicketeh china the chinese chicken, you have?
34
Rep 790
Drives: 335ci hold out
A professional alignment shop could fix this problem right?
"In Soviet Russia car forks you!"
02-12-2006, 07:15 PM | #5 |
34
Rep 790
Any camber solutions out there yet?
02-12-2006, 10:26 PM | #6 |
574
Rep 6,750
I was talking to Mava and he has the H&R race 2" drop on his car, and was able to have the camber adjusted adequetly.
I've decided not to drop my car for two main reasons. Although I love the look, I occasionally will scrape the curb ahead of me when parking. It won't get any better when lowered. When parked parallel to a curb, I don't need to worry as much about passengers opening the doors into the cement. |
02-12-2006, 11:52 PM | #7 | |
34
Rep 790
03-09-2006, 11:57 PM | #8 |
MAUI BUILT
485
Rep 7,781
I've been driving like the car is lowered out of habit even though I'm still looking at my springs(living room) and still waiting for shocks. There is one driveway that I used to scrape all the time, but since I have started drivng the e90, I don't. I know I will scrape again once the car is lowered unless I cut the entry/exit at 45 degrees. I also back in alot to avoid hitting the front against the parking stops.
Danny
03-10-2006, 12:28 AM | #9 |
52
Rep 1,024
Just thought I'd add that I believe Dinan has camber plates for the E90 They're set to add negative camber. They seem expensive though, but I've never bought camber plates before so I guess I wouldn't know.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
03-10-2006, 06:30 AM | #10 |
574
Rep 6,750
I had camber plates installed on my 260Z. They were welded onto the tops of my strut towers and were easy to adjust in either direction.
03-10-2006, 11:07 AM | #11 |
Moderator
497
Rep 27,441
my advice is to lower it first, and then get an alignment. from that point, see if you need a camber kit. if you doing mild lowering, with h&r sport or eibach pro-kit, i'm thinking you'll most likely not need a camber kit. this is my experience from my past bmw.
honda's on the other hand are a different story. i'm also used to driving a lowered car. even though my e90 is not lowered yet, i still drive it like it is.
03-12-2006, 05:49 AM | #12 | |
missing two turbos.
577
Rep 4,859
Drives: fast around corners.
Myself too, coming from lowered vehicles.. I drive my E90 as if it was slammed. Going extremely slow over bumps, trying to avoid every little dips/potholes on the highway, slowing down when going up/down the steep road, etc etc, all this which is unnecessary with current ZSP suspsnion. Pathetic human beings. They can't adjust to changes fast enough.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
03-13-2006, 12:27 PM | #13 |
Moderator
497
Rep 27,441
hahaha. it's all in good practice. i'm planning on lowering the e90 anyways. remember to go into those driveways at an angle.
03-13-2006, 01:38 PM | #14 | |
Digital Ruler
Rep 166
I'v had cars that I ran 2-3 degrees of camber on and had NO adverse tire wear on a car with properly set toe. I had a civic with a toe out issue and burned through a set of tires in about 7000 miles. |
03-26-2006, 10:44 AM | #15 |
Rep 21
So can anyone answer whether or not cambers are required if you drop your car? There are so many people saying they lowered their cars but no mention of camber adjustments. I spoke with a BMW rep and he was not sure if the E90 came with adjustable cambers. I have had problems in the past with bad tire wear and don't want to make that same mistake. Has anyone actually worried about cambers or did they all just lower the car and pray for no premature tire wear. You would think this was the first time anyone lowered their cars or this would be answered already!
03-26-2006, 11:01 AM | #16 | |
574
Rep 6,750
03-26-2006, 12:08 PM | #17 |
MAUI BUILT
485
Rep 7,781
For Sport type springs with a minimal drop, camber kits are not required. For more agressive drops, they might be needed. Here are my specs after my alignment with H&R Sport Springs and Koni Shocks (if I had the race springs, I would've needed a camber kit):
Front Left: Camber: -0.3" Caster: 7.2" Toe: 0.11" SAI: 14.3 Included Angle: 14.0" Front Right: Camber: -0.7" Caster: 7.2" Toe: 0.11" SAI: 14.4 Included Angle: 13.7" Front: Cross Camber: 0.4" Cross Caster: 0.00" Cross SAI: -0.1 Degree Totall Toe: 0.22" Rear Left: Camber: -1.5" Toe: 0.17" Rear Right: Camber: -1.6" Toe: 0.17" Rear: Cross Camber: 0.1" Total Toe: 0.34" Thrust Angle: 0.00 The only thing that is not within factory specs is my front right camber, it's off by 0.1" from factory range which is 0.0 to -0.6. Danny
03-27-2006, 04:08 PM | #18 | |
Rep 21
03-27-2006, 04:42 PM | #19 | |
MAUI BUILT
485
Rep 7,781
Danny
04-01-2006, 04:55 PM | #20 |
Rep 21
So does anyone know if the non sport has the same type suspension in regards to zsp? I would think zsp has some upgrades but would that also include adjustable dampers or cambers? Lastly, has any non sport owners lowered their cars and only had alignment done to correct the problem ?
04-01-2006, 07:29 PM | #21 | |
MAUI BUILT
485
Rep 7,781
Danny
04-02-2006, 05:02 PM | #22 | |
34
Rep 790
Good stuff, i'll look out for that next time
