3m 1080 vinyl
04-06-2015, 05:38 PM | #1 |
48
Rep 374
3m 1080 vinyl
Looking at doing my interior in one of the brushed metals. Does anyone know what direction the grain runs? Say I buy a 5x3' roll, does the grain run the long way or short? Obviously the dash piece is rather long and I would need 5x4 if it runs the shorter direction. Thanks.
04-06-2015, 06:34 PM | #4 |
530
Rep 2,083
The CF is close to symmetrical (the rectangles in one direction are slightly longer than those in the other direction) so it wouldn't be too bad if its switched. But the brushed metal stuff definitely needs to be in the right direction.
2013 135is DCT Carbon Black Metallic |
04-06-2015, 10:30 PM | #5 | |
BimmerPost Supporting Vendor
469
Rep 4,938
I'm not sure on the Metallic scotchprint though
04-06-2015, 10:39 PM | #6 | |
530
Rep 2,083
It's all preference on which way the pattern goes when applying it. If I was doing the 1080 I would want the longer rectangles to be parallel to the ground. on the long dash piece. The difference is pretty minimal though.
04-07-2015, 08:25 AM | #7 |
48
Rep 374
The patterns all run from top left to bottom right (from 3M site) so basically it all runs the width (NOT the 5' standard roll height) so if you want brushed metal you are kinda screwed into buying a 5x4' when you really only need 5x2 or 5x3 at most. Like said earlier, CF is more preference but either way would work.
04-07-2015, 02:31 PM | #8 |
A family of bimmers
2748
Rep 7,742
i ordered from AVS and they told me they cut it with the pattern the long way and then trim the sheet to the width i order. Double check with the vendor you choose. I like AVS and MetroRestyling for vinyl vendors.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
04-08-2015, 09:52 AM | #10 |
Carbon Fiber Everything
12
Rep 74
Drives: 2009 328i xDrive
3M 1080 Carbon Fiber vinyl.
http://www.e90post.com/forums/showthread.php?t=1103538 It looks amazing and most of it turned out pretty good. However Im a cursed perfectionist and am not happy with how the corners/ends turned out. The carbon fiber vinyl is pretty thick as I imagine the brushed aluminum is as well. When covering it you have to stretch it with heat and the heavier vinyl regains its shape. Makes wrapping a bit more difficult.
04-08-2015, 01:47 PM | #13 |
530
Rep 2,083
Where did you order your sheet from?
04-15-2015, 12:34 PM | #14 |
11
Rep 136
I made a $51 offer and they accepted. I am pretty sure this is the cheapest price anywhere.
http://www.ebay.com/itm/60in-x-36in-...item58a1488fe2 |
