Which angel eyes are good and cheap
03-29-2015, 10:41 PM | #1 |
18
Rep 102
Hi got a 2009 bmw 328i xdrive sedan with halogen headlights. Which brand of angel eyes led are good and cheap.
03-30-2015, 10:21 AM | #4 | |
18
Rep 102
03-30-2015, 11:48 AM | #5 |
3441
Rep 79,211
You may want to consider the HPB 160 Watt Total output (80W V2). We've sold 100's problem free.
Edit- Just realized you have halogen so you'd need the E90 LCI Angel eyes from HPB 80W Total Output. Last edited by Jeff@TopGearSolutions; 03-30-2015 at 02:21 PM.. |
03-30-2015, 12:08 PM | #6 | |
BimmerPost Supporting Vendor
469
Rep 4,938
Also just remember that the H8 bulbs styles will not work with your car since you have halogen headlights. There are a lot more options out there for the H8 ones
03-30-2015, 02:20 PM | #7 | |
3441
Rep 79,211
03-30-2015, 02:40 PM | #8 | ||
18
Rep 102
03-30-2015, 03:09 PM | #9 |
36
Rep 407
The LCI angel eyes are very cheaply made which barely reflect any light. Even if you get a very high output LED bulb, the chances are you cannot see them in direct sunlight. But in slight cloud cast, they are very neatly visible. So be warned about this trait.
And definitely go with good quality ones as it is a pain in the back to replace them if one of the bulb blows out. You might save a few bucks with cheap bulbs but then more trouble to replace them. |
03-30-2015, 03:46 PM | #10 |
36
Rep 407
Also you are probably already aware that you can code the angel eyes to be your DRL using the BMWhat app and an ELM32 wifi module. You can also change the brightness there. Or if you are a coding expert, you can do that method too. No need for any harness to enable your angel eyes are DRL.
03-30-2015, 03:55 PM | #11 | |
18
Rep 102
03-30-2015, 04:50 PM | #12 | |
469
Rep 4,938
03-30-2015, 09:04 PM | #13 |
36
Rep 407
Well I see brightness control when I go through the BMWhat app. So I am not sure if changing that value does that anything at all. Even at full brightness, with the stock angel eyes, I am barely seeing the light during day time.
03-30-2015, 09:40 PM | #14 | |
3441
Rep 79,211
The lights are better seen from a distance of about 30 feet and level with the headlight. |
03-31-2015, 09:36 AM | #15 |
36
Rep 407
Thats good to know. Only if I had known this earlier .
I took the plunge and doing a projector and Orion V2 retrofit just because I hate my halogen headlamps http://www.e90post.com/forums/showthread.php?t=1107362 |
03-31-2015, 11:17 AM | #16 | |
3441
Rep 79,211
These plug and play system can be had for sub $100. They are a significant improvement over stock but can't be compared to custom retro-fit rings. |
04-02-2015, 12:50 AM | #17 |
46
Rep 357
Anyone know if the DTEC v9.5 LED driver module touching the metal heat sink on the bulb causes any problems? Installed these in my LCI E90 yesterday and the only way to fit everything in the housing and put the cover back on was to shove it in all together with wires as well as the driver in contact with the heat sink.
04-26-2015, 04:33 AM | #18 | |
860
Rep 35,253
