03-29-2015, 01:00 PM | #1 |
597
Rep 1,805
Need some help on removing steering wheel trim
In the middle of a little steering wheel project.
Need some help on how to remove the aluminum trim on this part (i'm replacing with a carbon fiber piece). Here are the pics... Looks like it's some sort of metal tab with 4 hooks holding on to a metal stub. Should I just push these through? I'm worried about bending the metal housing and I they won't properly hood the new replacement piece. Thoughts?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
03-29-2015, 01:40 PM | #2 |
265
Rep 807
Pretty easy to remove. Take a small screw driver and pry the metal tabs back on the clips. They should just loosen up. To reattach, flatten the tabs back down on the clips and press them back on.
03-29-2015, 01:43 PM | #3 | |
597
Rep 1,805
I might get the dremmal out and try to grind the tips off. I've got 2 of the 6 off using very sharp metal pick but I've practically destroyed the metal tabs, not sure I can reuse them those 2. Might have to use an epoxy to reattach the carbon fiber part.
03-29-2015, 02:22 PM | #4 |
1312
Rep 10,185
A good hardware store should have new ones of those tabs for you.
Or the dealer or Amazon ect ect BMW calls it a "spring nut" Other name is "push nut"
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 03-29-2015 at 02:29 PM.. |
03-29-2015, 02:39 PM | #5 |
597
Rep 1,805
Good Man, thanks.
03-29-2015, 03:57 PM | #6 | |
597
Rep 1,805
http://www.ecstuning.com/ES2748862/?...FYI_aQodBJIAow Another man's struggles. http://www.bimmerfest.com/forums/showthread.php?t=18075
05-13-2015, 11:12 AM | #9 | |
1312
Rep 10,185
1) Remove the battery negative cable from the car (Due to removing airbag) 2) Put a screwdriver in the airbag unlocking hole at teh back of the steering wheel and unclip the airbag (Look this up as it can be tricky) 3) Unclip the airbag control wire and set airbag down with the BMW roundel facing up 4) Unscrew 1 trim holding screw at the bottom rear of steering wheel (behind the trim) 5) Unscrew the 2 screws holding the top of the trim in (behind where the airbag was.
BMW if you are reading, I need a job, Please. |
