Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      03-28-2015, 04:51 PM   #1
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Coding
Help. Have the proper cable via ebay and link for the car and I've downloaded ESYS and the premium Token Launcher as well; but when I attempt to run the program and start up ESYS am unable to see my car in the target section. Its blank. See the VIN noted down under connect via VIN selection but am unable to do anything past that as nothing shows under the target box. See attached.
Help? What am I doing wrong? Car is running and all. 1st time coder. Build date is 11/14 F80 M3
Thanks
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      03-28-2015, 04:57 PM   #2
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Forgot screen shots. Should I have the firewall or antivirus software turned off just wondering why it would not find a target vehicle but would read the VIN unless the vehicle is locked down by BMW for Coding?
      03-29-2015, 07:31 AM   #3
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
No data files? You should have selections up top if your data was loaded correctly.
      03-29-2015, 04:52 PM   #4
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
How do you load data? Not sure what I did wrong
      03-29-2015, 06:30 PM   #5
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
The data was one of the archives you downloaded. The big one. In the instructions it tells you to move the pzdata folder (making sure you deleted the existing empty folder).
      03-29-2015, 07:40 PM   #6
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Okay got that part but am getting this error message when I try to read coding from SVT files...before trying to edit:
Transaktions-Report: Aktion: Codierdaten lesen
FEM_BODY [40] [P804548]
readCPS o.k.
CAFD_00000794_012_035_117 Fehler:
File for "cafd_00000794-012_035_117" not found! [C012]
What does this mean? Fix?
      03-30-2015, 08:02 AM   #7
WHK
50
Drives: 2015 M4
There are two missing files that you'll run into. Fortunately, you can download and install those files easily: http://www.bimmerfest.com/forums/sho...2&postcount=12
      03-31-2015, 12:00 AM   #8
mdrobc13
mdrobc13's Avatar
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Link did now work.
      03-31-2015, 07:59 AM   #9
WHK
50
Drives: 2015 M4
Sorry, that had only an abbreviated version of the right link. Here's the whole thing. http://www.bimmerfest.com/forums/sho...2&postcount=12
f80post
