E92 LCI Front Msport Upgrade Parts List?
03-26-2015, 01:49 PM | #1 |
64
Rep 548
Hey guys, I have a 2011 e92 lci non-msport and I am thinking about upgrading my front bumper to the msport bumper. I just converted my rear to an msport and I want to complete the look.
So my question is if anyone has an indepth part list? I know I need the bumper cover but as for everything else I need to know what needs to be replaced and what doesn't need to be replaced. I would love to hear from the people that have done this and would love to know the specific part numbers. I can find a bumper cover for relatively cheap but I'm trying to gauge how much this is gonna cost with the rest of the odd parts. Thank you in advance, I hope this thread will help me and continue to help others with a specific list of things needed for the upgrade.
2011 AW / CR 6MT 335i Xdrive Coupe | JB4 Stage 2 | BMS Intake | Performance Spoiler | Powder Coated Red Linea Corse 818 | Blacked Out Roof | Wrapped Interior Trim
03-28-2015, 11:14 AM | #3 |
64
Rep 548
bump.. I know someone out there has the done this before
10-18-2015, 05:42 AM | #4 |
166
Rep 429
Drives: 2011 e92 335xi
I tried my best to figured it out. I might have missed something so please feel free to chime in.
These are parts needed to upgrade an e92 LCI 335i non m-sport with PDC. ======= FOR THE FRONT ======= screw: 6 piece 07119904263 plastic screw: 4 piece (REUSABLE) 07143428231 Trim screw: 4 piece (REUSABLE) 07147129160 Spacer sleeve: 4 piece (REUSABLE) 51117071270 Torx bolt: 4 piece (REUSABLE) 07146959923 Seal, engine bonnet (REUSABLE) 51767225268 Trim cover, bumper, primered, front 51118035783 Adapter strip, engine bay EMI insulation 51758044389 INSERT, BUMPER FRONT LEFT 51117227897 INSERT, BUMPER FRONT RIGHT 51117227898 Grid lateral left 51118038935 Grid lateral right 51118038936 Grid, center 51118047402 Air duct front left 51748047407 Air duct front right 51748047408 Air duct, brake, left 51748047409 Air duct, brake, right 51748047410 Flap, towing eye, primed 51118035799 Set of mounts for PDC sensor, front 51117256098 Cover, spray nozzle, primed left 61677253393 Cover, spray nozzle, primed right 61677253394 Support, fog lamp left 51118048773 Support, fog lamp right 51118048774 M-Sport Fog Light - Left 63177839865 M-Sport Fog Light - Right 63177839866 H11 Halogen Light Bulb: 2 pieces 63217160784 REP. KIT FOR SOCKET HOUSING: 2 pieces (not sure about this one) 61132360041 Flat Pin Connector With Wire Lead: 2 pieces (not sure about this one as well) 61130007272 ======= FOR THE REAR ======= C-clip nut, self-locking: 7 piece (REUSABLE) 07146951655 Bumper trim panel, primered, rear 51128044934 Bracket, PDC-sensor rear interior left 51128044387 Bracket, PDC-sensor rear interior right 51128044388 Bracket, PDC-sensor rear exterior left 51128044385 Bracket, PDC-sensor rear exterior right 51128044386 Flap, towing eye, primed 51127893147 Cover, bumper, rear 51128041192 Guide, bottom center (small) 51127161506 Guide, bottom center (large) 51128044375 from ecs tuning: Part list for front bumper Part list for rear bumper (The diffuser is not included. Just buy what you like ) EDIT: Replaced M - Tech Bumper Adapter Strip 51758045386 with Adapter strip, engine bay EMI insulation 51758044389 I later realized 51758045386 is for e93 only. 51758044389 is correct part for e92. I've updated the link to cart as well. Last edited by Supermoon; 10-27-2015 at 09:43 AM.. Reason: fixed url + added foglight units |
10-19-2015, 02:09 PM | #5 |
64
Rep 548
Supermoon Can any of the pieces listed for the front bumper be gathered from the original non-sport bumper? (i.e like the engine/bonnet seal, some screws/clips, adapter strip, inserts)
10-26-2015, 07:45 AM | #6 | |
166
Rep 429
Front bumper: ----------------------- Plastic screw (07143428231) Trim screw (07147129160) Spacer sleeve (51117071270) Torx bolt (07146959923) Seal, engine bonnet (51767225268) --------------------------------------- Rear bumper: ------------------------- C-clip nut, self-locking (07146951655) ---------------------------------------- Thanks for pointing it out Chris_Rav. I also edited the list for the front because I added a wrong item. Check the EDIT message. I've sent the links to cart to BMW specialist team at ECS tuning and they said the lists are very complete and accurate.. But I'm thinking 51117256098 (mounts for pdc sensor) might be unnecessary with 51118035783 (bumper for pdc). Same goes for the rear (51128044387, 51128044388, 51128044385, 51128044386). I would suggest buying them as well and returning them if they end up not being used. Last edited by Supermoon; 10-26-2015 at 08:07 AM.. |
10-26-2015, 07:59 PM | #7 |
136
Rep 1,192
Drives: 2011 335i MT
I swear, using Google to do a search is a dying art:
http://www.e90post.com/forums/showthread.php?p=8140019
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
10-27-2015, 09:06 AM | #8 | |
64
Rep 548
10-27-2015, 09:09 AM | #9 |
64
Rep 548
Supermoon The link to the front bumper cart is not working for me currently, but this information has been very helpful and I am sure it will help many others as well
10-27-2015, 09:29 AM | #10 | |
166
Rep 429
My car's dropped off at a body shop. Changing the rear bumper only this time. I'm considering 1m rep over m-sport.. it's hard to decide! If I end up doing m-sport I'll post some pictures on this thread. |
10-27-2015, 09:36 AM | #11 | |
64
Rep 548
I believed I had all the parts until I saw this list. It looks like I am going to need to pickup the M-tech bumper adapter strip, Bumper insert left/right, Hood insulation strip, and a few screws.
03-25-2016, 06:12 AM | #12 |
Rep 50
Did you end up getting this done? I just bought an msport front bumper(used, off an OEM msport) and this is kind of scaring me. from the pre-lci thread it looks like the cooling duct's aren't going to fit properly
04-01-2016, 08:53 AM | #14 | |
64
Rep 548
My car is finally going to the body shop later today to get the msport bumper finally put on. Its been quite a process to say the least.
04-01-2016, 10:00 AM | #15 |
Rep 38
No it doesn't correctly line up. End of sides holes, but others not. Do you mean under cover for M sport? If you buy it, you have to buy wheel arch as well.
04-01-2016, 09:05 PM | #16 |
64
Rep 548
Did you buy the Msport under cover and wheel arches or did you just make it work?
Tags |
e92 lci msport, lci conversion, lci front, lci msport, msport front |
