03-23-2015, 01:57 AM | #1 |
15
Rep 177
Creaking Seat
Hi my drivers seat creaks under lateral load. Its at the point it is annoying on every journey.
Dealer has had it in twice, adjusted and lubed but still doing it. Anyone else having this issue? I am thinking that I ask for a new seat, is that unreasonable? Car 16mths old, with leather memory seats. |
03-23-2015, 02:59 AM | #2 |
1135
Rep 2,808
Same here - it does my head in!! My F30 is in for a service today and I asked for them to look at it, it has memory seats as well. Will report back if they sort it.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
03-23-2015, 03:02 AM | #3 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
I had this issue intermittently and dealer always said they couldn't replicate the fault.
My issue was coming from what sounded like the left side bolster m, so when going round right hand corners. I cured it by spraying wd40 into the left side seat hinge mechanism. I opened it out and sprayed in, then closed the seat up and back down a few times to let it work in. Creaking was then gone! I had to repeat once a few weeks later, but that was 6 months ago now and it's not come back. Worth a try?
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
03-23-2015, 03:51 AM | #4 |
84
Rep 729
This is a long shot, but I had a similar thing on my last BMW that turned out to be the edge of the seat compressing against the seat belt buckle under lateral load making the leather creak. It took me ages to work out that it was something so simple.
03-23-2015, 04:55 AM | #5 | |
1135
Rep 2,808
03-23-2015, 05:09 AM | #7 |
8567
Rep 19,982
Id definitely get it replaced if it was to continue, as agreed very annoying.
However, given the amount of bad stories I've heard of how seats look after work has been carried out on them Id rather avoid that.
03-23-2015, 05:49 AM | #8 | |
15
Rep 177
03-23-2015, 05:50 AM | #9 |
15
Rep 177
03-23-2015, 08:05 AM | #11 | |
8567
Rep 19,982
Interesting to note that everyone who is reporting this issue has electric seats... Wonder if it is related to how these work then?
03-23-2015, 08:58 AM | #12 |
Fool
1857
Rep 3,542
Furniture polish is commonly used to lube window fittings because it lasts a decent time and produces a slick, low friction surface. Of course if you have proper lube, you might as well use that, but WD40 is not a lubricant.
03-23-2015, 09:26 AM | #14 | |
8567
Rep 19,982
No doubt there is something in the shops that's perfect but was using what was around in the garage to see if it helped.
03-23-2015, 09:50 AM | #15 | ||
44
Rep 275
03-23-2015, 06:57 PM | #16 |
128
Rep 588
Drives: F30 320d & G29 M40i First Edtn
It's all about GT85 as its actually a lubricant. Excellent stuff - give it a go
03-24-2015, 04:29 PM | #17 |
15
Rep 177
03-24-2015, 05:28 PM | #18 |
1135
Rep 2,808
2 days in the dealer for the first service anyway...
They told me they had 'greased' the joint and at the moment there is no squeak. Although I have done this before and after about 2 weeks it's back. Lets see what happens...
03-24-2015, 07:56 PM | #19 | |
551
Rep 980
03-25-2015, 03:29 AM | #20 |
15
Rep 177
well we need to start complaining as otherwise BMW will not see the scale of it and we will continue to be fobbed off as a one off, or too fat etc... etc.. etc...
Lux700 are yours electric too? |
03-31-2015, 08:21 PM | #21 |
551
Rep 980
Sorry Ben, I've been away... Yes, electric seats. If I change the position it stops, but then I'm sat in a position which is no good for me. The good thing is that this is the only problem I have with the car. 4400 miles now.
04-01-2015, 10:18 AM | #22 |
15
Rep 177
quick update - they couldn't get it to do it last time it was in ... but for me its back ... so agreed I will take it in and show them....
but has anyone found a permanent solution to this? |
