03-21-2015, 10:16 AM | #1 |
Rep 20
Mirror Folding coding
I was playing around with coding but I couldnt get the car to do what I wanted it to do. I am trying to get the mirrors to unfold immediately when the car is unlocked via the fob or comfort access. I also dont want the mirrors to fold with the fob or CA, I would like to have to put them in manually. However, I wouldnt be opposed to having the mirrors fold after holding down the fob button if that was a requirement.
Here is what I coded: 3053 - KOMFORTSCHLIESSUNG_FB = aktiv 00 3053 - KOMFORT_SCHLIESSEN - WERTE = 0F... I also tried 00 3110 - ASP_BEIKLAPPEN = aktiv (this as like this from the factory) 3110 - ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv Am I missing soemthing? I also coded the euro anti-dazzle LED headlights but I like in a city where I think the car thinks it is too bright to activate them. Is there a way to tell they are working or coded correctly without guessing if the car thinks its dark enough and working? Thanks in advance
'86 325es M-Technik1 s54b32TU 6-speed
'89 325is m20b25 5-speed '15 M4 MPerformance s55b30 6-speed |
03-24-2015, 10:30 AM | #3 | |
Rep 20
Anyone know if you can just have them fold out with CA and not fold in?
03-25-2015, 01:00 PM | #5 | |
Rep 20
Mine will not fold out... but then I didn't use the code to get them to fold in via fob
03-25-2015, 02:10 PM | #6 | |
224
Rep 516
03-25-2015, 09:01 PM | #8 | |
15
Rep 46
My mirrors unfold upon unlocking, but only if they were folded in by holding the lock button on the fob. However, if I fold the mirrors via the button on the door panel, they do not unfold when unlocking. Here's what I changed: FEM_BODY 3053 KOMFORTSCHLIESSUNG_FB FEM_BODY 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN All set to aktiv |
03-26-2015, 09:00 AM | #9 |
Rep 20
Ugg... that's exactly what I didn't want to hear. Thanks for the info though.
03-27-2015, 11:17 PM | #12 |
Christmas Poo
1017
Rep 1,174
I can confirm also that if you fold mirrors manually from the door panel before you leave the car they won't unfold automatically when you unlock. If I fold the mirrors with the key fob then they will automatically unfold when I unlock with key fob. You can also code a speed at which they automatically unfold if you don't want to touch the key fob to unfold...set it to 1. when the car moves they unfold.
04-12-2015, 06:45 PM | #14 |
75
Rep 991
Drives: 2015 BMW M4
Can you confirm your values via screenshot? Haven't had an issue with this yet personally, so curious to see what might be going on.
2015 ///M4 F82 [ Mineral Grey | SO Ext | 19" Black | 6MT | CFRP Interior | LED | Executive | Side/Top Cameras | Adaptive M Suspension | HK Surround ] :: will code locally for rum, beer, or chicken; PM as desired :: Instagram: IMrMark |
04-12-2015, 07:23 PM | #15 | |
10424
Rep 40,720
Drives: 2018 Alpina B6 650ix GC
If that works, then code KOMFORT_SCHLIESSEN = Werte=01 to change it to a 1 Second delay.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-12-2015, 10:27 PM | #17 |
10424
Rep 40,720
05-03-2015, 06:39 PM | #19 |
10424
Rep 40,720
You have to press and hold for as long as the duration defined in FEM_BODY => KOMFORT_SCHLIESSEN.
05-03-2015, 07:53 PM | #20 |
654
Rep 1,095
05-03-2015, 08:38 PM | #21 |
10424
Rep 40,720
No. It is written above. Werte 01 = aktiv. This is not a timing function. It is toggled between enabled and disabled states.
11-23-2015, 12:34 PM | #22 | |
523
Rep 1,105
Unlocking the car using either comfort access or the key FOB immediately unfolds the mirrors which is perfect. Can someone tell me how I can have the mirrors fold immediately? |
