FS: 335i/Z4 35is/E82 Front Caliper Assemblies, Rotors and Pads
03-17-2015, 09:29 PM | #1 |
Слава Украине!
2336
Rep 2,443
Caliper assemblies: $350.00 +shipping
Rotors: $340.00 +shipping Pads: 110.00 +shipping Buy it all: $700 +shipping Prefer to sell locally, will deliver in the SF Bay Area between Palo Alto and Tracy A word of warning: Although 17" are a stock size on E9x 335i's, not all 17" wheels on an E82 will fit over the calipers, ask me how I know. My 207Ms didn't. There's interference where the barrel tapers to a smaller diameter before mating up to the spokes and I'm running a 12mm spacer. A 15mm spacer may make it work but it'll still be very tight. 18" wheels should be no problem, but you may still need spacers on an E82 to keep the calipers away from the spokes depending on what offset you're running.Obviously, genuine BMW 17" wheels meant for the 335i will work fine. BRAKE ASSEMBLIES Calipers: Degrease Mask off all areas NOT to be powder coated Glass bead blast Degrease again Clean in trisodium phosphate (TSP) Phosphoric acid etch to remove oxidation Treat with Alodine 1201 to prevent oxidation and improve paint adhesion Powder coat gloss black Carriers: Degrease Mask off all areas NOT to be powder coated Glass bead blast Degrease again Clean in trisodium phosphate (TSP) Phosphoric acid etch to prevent oxidation and improve paint adhesion Powder coat gloss black Assembly: All new parts Genuine BMW seals and dust boots, "Repair set brake caliper" 34116769090 Genuine BMW "Ventilation valve" (bleeder) 34116768018 Genuine BMW "Dust cap" (for the bleeders) 34111163435 Genuine BMW "Clip" (anti-rattle) Genuine BMW with their faces painted high-temp hyper-silver (Made no sense to powder coat a wear item) Bimmerworld solid brake guide kit BRAKE ROTORS Genuine BMW Z4 35is "Brake rotor, light blue, ventilated" 34116782593 BRAKE PADS Genuine BMW 34116794920 |
03-25-2015, 11:17 PM | #3 |
68
Rep 213
those calipers are so sexy...very tempting. Where in the bay are you located?
03-26-2015, 07:04 AM | #4 |
Слава Украине!
2336
Rep 2,443
06-13-2015, 01:30 PM | #8 |
Слава Украине!
2336
Rep 2,443
