03-16-2015, 04:02 PM | #1 |
10995
Rep 32,881
I Love Michelin Pilot Super Sport's!
I've done over 100 miles on them now, and i am back in love with my car! They're just better than the S001 run flats in every way, steering is lighter and more direct, less road noise & smoother ride.
I do think they need the ACS springs though, as they've softened the ride a bit they'd probably make the car too soft on the standard springs, especially on xdrives and non M Sports. |
03-16-2015, 04:16 PM | #2 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Better late than never!
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
03-16-2015, 04:22 PM | #3 | |
1219
Rep 1,319
03-16-2015, 04:28 PM | #4 | |
3489
Rep 9,709
You know there are some mods that you can't recommend enough, yet are slow to filter through. MPSS is definitely a massive improvement, well just NRF, but non better than MPSS. Glad you have seen the light |
03-16-2015, 04:37 PM | #6 |
3531
Rep 11,292
Interesting you say the steering is lighter, I like the sound of that. I don't like the weighted Sport steering as it actually hurts my shoulder after a long journey if I leave it in Sport
What pressures you running at? Same as run flats?
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
03-16-2015, 04:42 PM | #7 |
8567
Rep 19,982
I think we need a debate and then definitive list of the best mods in priority order!
03-16-2015, 04:46 PM | #9 |
3531
Rep 11,292
I think you once said you rated the tyres as a better improvement over the springs?
03-16-2015, 05:08 PM | #10 | |
Supreme Being
1804
Rep 5,425
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
03-16-2015, 05:12 PM | #11 | |
10995
Rep 32,881
I'm pretty sure that the run flats contact the road much harder on the outsides and are basically running on the side walls, hence the poor handling characteristics. |
03-16-2015, 05:17 PM | #12 | |
8567
Rep 19,982
If I could only do one or the other though I'd probably have to do the springs though.
03-17-2015, 03:17 AM | #13 | ||
165
Rep 942
Mine F31 330dx recommends 2.4 all around for the 19" RFT's. What am I missing?
2016 F80 M3
03-17-2015, 03:49 AM | #14 |
3531
Rep 11,292
According to the Kwik Fit online tyre pressure finder his car should be 2.6 bar (37PSI) all around for 19's. Which is actually the same as my 335d.
03-17-2015, 04:01 AM | #15 |
10995
Rep 32,881
Yours is different to mine, 2.6 all round for light load, 2.8 & 3.1 for heavy load. 2.6 felt really bad so i tried 2.8 in an effort to improve things which did a little bit.
03-17-2015, 04:01 AM | #17 |
3719
Rep 8,636
03-17-2015, 06:58 AM | #19 |
10995
Rep 32,881
I thought i'd give 2.4 bar all round a go, and i'm impressed! Although the steering is slightly heavier, i'm sure the ride comfort and grip has improved!
Also from reading some bits in the net about the Alpina D3 & B3 (which come with PSS's) it appears that the common opinion is that they are best at 2.4 all round, so i think i'll stick with this. |
03-17-2015, 08:15 AM | #20 |
165
Rep 942
Yours is sDrive and 4dr, so in theory lighter at both ends than mine, yet had recommended pressures that were higher; very odd, you would have expected things to be the opposite way around. Makes sense therefore that yours should drive a bit better with the lower pressures I guess.
The Alpina also runs wider tyres front and rear, fronts are 245/35, rears 265/30, not that that should make much difference.
2016 F80 M3
03-17-2015, 08:21 AM | #21 | |
10995
Rep 32,881
The 330d sdrive saloon just gets in under the 130g/km so maybe BMW had to increase the tyre pressures to achieve that. But the xdrives and tourings are over it whatever they did so they could use the more suitable pressures for those models. |
