ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      01-27-2008, 07:00 PM   #1
kav
49
Drives: Z4M
Z4M offset quick help please.
I'm considering some new wheels and would really like to stick to the stock size rims.
Stock
Front wheel 18 X 8 Offset 42
Rear wheel 18x9 offset 30
New Rims
Front wheel 18x8 offset 34
Rear wheel 18x9 offset 40
Using a wheel offset calculator it says that:
Front - Inner clearance 8mm MORE & Outer position EXTEND an extra 8mm
Rear - Inner clearance 10mm LESS & Outer position RETRACT by 10mm
What are your thoughts on the clearance with these offsets as well as overall stance?
After some feedback on another forum, I'm considering running the above setup with either 10mm spacer, to bring the rear out to stock offset, or 20mm spacer to move the rear out about 10mm to match the front.
I any advice you could provide quickly would be a huge help.
      01-27-2008, 07:32 PM   #2
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
I have no idea how offset works, but if you go with what tirerack says you should be fine. I've never seen anyone complain about advise they got from tirerack.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      01-27-2008, 07:41 PM   #3
kav
49
Drives: Z4M
I'm trying to figure this out myself since the wheels aren't from tirerack... Any other advice.
      01-27-2008, 08:39 PM   #4
VoiD
14
Drives: Z4MC >>> C63
2007 Z4 M Coupe  [0.00]
front should be fine.
rear might need spacers.. it might rub in the inside where the shock is..
      01-27-2008, 08:42 PM   #5
kav
49
Drives: Z4M
What about with a 20mm spacer in the back. This would move the wheels out 10mm past the stock position.
      01-27-2008, 08:53 PM   #6
VoiD
14
You might be okay but I think 20mm is too much..
10mm = ~2/5 inch.. See if it'll start rubbing on the outer side where the fender is..
      01-27-2008, 09:02 PM   #7
kav
49
Drives: Z4M
You really think 10mm would be too far out on the rear? The fronts are 8mm extended outwards. I thought it would match nicely. But you are right, I'd hate to be dealing with fender rolling, etc.
      01-27-2008, 09:34 PM   #8
Reach
gone baby gone
382
Drives: 2016 F80
You really don't want to mess with spacers if you can avoid it. What you really need is lower offset rear wheels. When you add spacers you're adding another fail point, more unsprung weight, and putting additional stress on your hubs.
      01-27-2008, 09:44 PM   #9
kav
49
Drives: Z4M
I have read this on some of the forums but I don't understand why this is the case. For all intensive purposes, if I added a 20mm spacer with longer bolts, wouldn't it be the same as if the wheels were -20 offset? Also the additional 2lbs literally on each hub, would be offset by 6 lbs of rotating weight loss.
Again, I am completely new to this and I am just trying to understand why spacers are seen in such a negative light.
      01-27-2008, 11:43 PM   #10
The HACK
The HACK's Avatar
1821
Spacers add stress points to the lug bolts. Imagine the shearing force between hub, rotor hat, and wheel, and add an additional piece of spacer in there...
I've seen sheared bolts at the track from running spacers. It's not pretty. For anything that sees moderate track use, if you're going to use spacers, convert everything to lug nuts instead of using bolts.
      01-28-2008, 01:34 PM   #11
Reach
gone baby gone
382
Drives: 2016 F80
...and the expression goes: "For all intents and purposes"
      01-28-2008, 01:50 PM   #12
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
I agree, and even if you don't track the car, the extra leverage acting on the bolts could cause you to exceed your maximum allowable sheer stress on the bolts if you hit a pothole going fast enough. Depends on a bunch of different variables, but unless you know the design conditions of the car I wouldn't mess with it either.
Best Website EVER!
      01-28-2008, 02:54 PM   #13
kav
49
Drives: Z4M
Great advice guys. Thank you..
      01-29-2008, 08:10 AM   #14
innerconx
Drives: 2004 Z4 2.5i
I'm running
19 x 8.5 235/35/ Front
19 x 9.5 265/30 Rear
Offsets are 35/40 no rubbing on stock suspension, with room for a drop.
There are some photos posted in this thread on Bimmerforums
http://forums.bimmerforums.com/forum...d.php?t=890163
Stock
New Rims
zpost
