F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > ConnectedDrive apps whilst driving...
proTUNING Freaks
      03-14-2015, 08:47 PM   #1
jdmagoo
Australia
8
Drives: 328i msport
So have just taken delivery of my new 328i and still learning the connected drive system. One of the many selling points of the vehicle was spotify integration using my iPhone. If i connect the iPhone via USB cable the spotify app becomes available under the connected drive menu, i can then browse all my playlists and have full cover art whilst playing music. The system works really well. But.... this only works whilst stationary with the vehicle in Park and the handbrake on. If i drive off with spotify playing the system continues to play the song but the spotify app in connected drive is greyed out, it displays a message "For your safety: certain applications can only be used stationary" -
Is there a way to disable this? I like switching between DAB radio and my music whilst driving and I can't do this with spotify. Once i drive off i cannot select the spotify app at all. So in order to do this whilst driving i need to pull over, put the car in park and apply the handbrake just to change my music source. This is crazy.
      03-14-2015, 11:10 PM   #2
jdmagoo
Australia
8
Drives: 328i msport
Work around...
Bit of a work around, if i start spotify through connected drive, then select the playlist i want and start playing; when i drive off the cover art along with the song information disappears and shows the warning as described above. Now if i exit out of this and select multimedia, then external devices and select my 'phone via USB' i will have my song details and cover art back along with skip forward and back. Still not ideal but at least now the screen isn't wasted.
      06-27-2015, 07:53 PM   #3
jvrb
jvrb's Avatar
Australia
Drives: X3 F25 LCI 20d
I've got the same problem whilst using the Tunein radio app (2015 X3 LCI with ConnectedDrive).
I can only select/change channels when stationary and the handbrake applied.
Once I start moving the app is greyed out and the screen doesn't display the Tunein info anymore.
Is there a way this can be changed?
      06-27-2015, 09:24 PM   #4
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
There's a setting to allow "Apps In Motion" but this needs to be coded through the OBD2 Port. If you do a search you'll find plenty of info...
      06-30-2015, 04:31 AM   #5
jvrb
jvrb's Avatar
Australia
Thanks. I couldn't find much in the X3 forum, but found this thread with useful information: http://f30.bimmerpost.com/forums/sho....php?t=1103696.
It seems to be an Australian issue.
      06-30-2015, 05:44 AM   #6
jdmagoo
Australia
8
Drives: 328i msport
Would love to know how you do this, there is no info that I can find saying it can be coded out. I think you might be confused with dvd in motion now that can be coded.
      06-30-2015, 12:25 PM   #7
Boxtyp3
Boxtyp3's Avatar
Philippines
78
Drives: 2015 F32 MG
2015 F32 435  [0.00]
2002 E46 cp  [0.00]
2010 E82 135i  [0.00]
2013 E92 335i  [0.00]
I think because you are connected through the BMW connect menu which is meant to work in stationary. If you open it through external devices it might work bec it is meant to work even in motion.
      06-30-2015, 07:12 PM   #8
rednose
Australia
65
Drives: F30 330i LCI M Sport
This is annoying me too, to the point where I may end up mounting my phone on the dash.
      06-30-2015, 07:52 PM   #9
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
I'm about to take delivery of my new car so been doing lots of reading about coding over the last couple of days. I swear I saw "Apps in motion" as well as Video but now can't find it...
      06-30-2015, 09:40 PM   #10
HFW003
HFW003's Avatar
Australia
5699
Drives: 2024 M340i xdrive
To the best of my knowledge this cannot be coded.
      07-02-2015, 04:14 AM   #11
jvrb
jvrb's Avatar
Australia
Exactly what I am thinking of doing. And just connecting it via usb.
The adaptor in the centre console, all though a great idea, limits functionality in Australia.
      07-25-2015, 07:06 PM   #12
tony8463
Drives: F15 2015
Yup. Me too.
      11-06-2015, 07:56 PM   #13
sawy3r
Drives: BMW X5 F15 xdrive40d
Jumping on the bandwagon. Same issue here in Aus with my F15. Damn.
Anyone work it out yet? Driving me nuts lol...
      10-23-2016, 09:37 PM   #14
marcosg
marcosg's Avatar
Australia
25
Drives: 2024 G05 X5 M60i
I have just taken delivery of F15 xdrive 40d and have the same issue with the Connected Apps. Even for me DVD in motion is limited to 60km/h with coding.
      10-27-2016, 11:53 PM   #15
MarcsM3
Drives: M3 Comp pack
Same issue on 2016 M3, and in the M3 there is no park option so once your moving you cant change songs at all unless you switch to USB mode. If you switch back to radio and back to USB playback of spotify, you have to pick up the phone to press the play button.
Its a crazy design flaw that is more dangerous than allowing control from the i-drive controller, just like picking a radio station. A bureaucrat has decided that because it has the word 'app' it cant be used on the move. who the hell signed off on this!! My wifes Mercedes just works, no issue and her car supports car play which adds a lot of functionality - all of which work when on the move
There has to be a sensible way of disabling the in motion function, otherwise you may as well use your phone and not bother with the car which defeats the object of 'integration', I cannot imagine BMW are not aware of the command to do this, or that someone hasn't managed to decode it. the issue seems to by limited to Australia and Hong Kong from what I can see
      10-28-2016, 05:32 PM   #16
jdmagoo
Australia
8
Drives: 328i msport
Bmw Australia are well aware of this, I sent them an email explaining the situation and they said there was nothing they could do as it was a requirement for them to get the idrive system and apps approved here in Australia. I explained (at the time) that the iPod player within idrive had a tonne more options that could distract me whilst driving compared to the Spotify app that I wanted to use; whilst they agreed with my logic, they said they couldn't do anything about it.
I was never able to find a way to code this out, the only real way was to replace the modules with overseas ones.
In the end I went with Apple Music which integrates really well with idrive.
      10-28-2016, 06:22 PM   #17
MarcsM3
Hi jdmagoo,
Thanks for the explanation, understand the approval process must be painful in Australia, many other manufacturers support native spotify integration so it can't be rocket science to allow that app only to be used on the move. Since the hardware is identical in other geographies, like NZ where there is no restriction, it must be easy to get someones e-sys file and look through for anything that is obviously different. It looks like its not an in-motion setting but some other setting/code
      02-21-2017, 03:24 PM   #18
eagerbees
Australia
Drives: BMW M2 (2016 F87)
Some interesting points here... doesn't bode well for a fix...
Sneaky bump for this thread - I have an F87 M2 with this issue in Australia...
Any advice on a work around would be amazing please...
TIA
      02-21-2017, 08:29 PM   #19
DOCTOR.Y
Eric_Y
Australia
103
Drives: 2016 340i, 2010 E92 M3
2016 bmw m3 f80  [0.00]
2010 M3 E92  [0.00]
Been talking to bimmertech and they suggest to try their 'service in motion'
      02-22-2017, 05:31 AM   #20
fuzzyboat9239
Drives: MY2017 440i GC
Surely there has to be a way, in my E92 i was able to access SMS messages and emails when the car was stationary in traffic which was great.
Now in my F36 I can't access anything unless it's in park with the handbreak on, so dumb!
      02-22-2017, 08:03 PM   #21
fuzzyboat9239
I emailed BMW Australia and asked why this is the case and this is the response I got:
"Thank you for your email. Regarding the functionality of SMS and Email messages, and ConnectedDrive apps, a vehicle needs to be stationary (defined as being in Park and the brake up). This is for BMW Group Australia to be in line with government regulations relating to Driver Distraction Laws."
      02-23-2017, 02:34 PM   #22
adge7
adge7's Avatar
Australia
25
Drives: F30 330i MSport
Perhaps the legislation changed since 2012, as my '12 F30 328i would display SMS when stationary (no hand brake/P selected necessary).
LCI 330i now requires both the hand brake and to be in park. Stupid.
f30post
