03-07-2015, 03:34 PM | #1 |
114
Rep 383
Black grills fitted, last mod - pic inside!
So I followed the numerous instructions to remove the original grills.
Move rubber bonnet seal, check Undo the trim bolts, check Locate grill tabs and push down, check Get annoyed and pull so hard the bottom grill tabs snap off, yup, On to the second grill and repeat, Before: After: So car is now complete. PPK Rear diffuser AC Schnitzer springs Black Grills 12mm spacers all round |
03-07-2015, 03:40 PM | #2 |
10995
Rep 32,881
Looks very nice!
Regarding the repeat for second grill bit though, why didn't you just put your hand through the hole where the first grill was!? Last edited by teaston; 03-07-2015 at 03:48 PM.. |
03-07-2015, 03:46 PM | #3 |
114
Rep 383
03-07-2015, 03:52 PM | #4 |
10995
Rep 32,881
So all of the bottom tabs snapped off?
I've snapped one off my black grills, i've bought some poly cement http://www.amazon.co.uk/Humbrol-28ml...s=Plastic+glue which should stick it permanently as it actually melts the plastic a little which effectively welds it together! |
03-08-2015, 10:48 AM | #8 |
3105
Rep 7,032
Drives: 335xd Msport +
Car looks good and at least you're not cluttering up the garage.
03-08-2015, 11:07 AM | #10 | |
78
Rep 577
03-08-2015, 11:18 AM | #11 |
10995
Rep 32,881
03-09-2015, 06:35 AM | #13 |
314
Rep 513
That looks very similar to mine except without the front splitter
Is yours an xdrive? The rear seems to sit a bit higher than mine after the ACS springs? Also what spacers did you use and where did you get them? I've been considering some ever since the ACS springs went on as it looks a little over arched...... I'm going to wait until I take off my winters though, the spray from those is terrible as it is, with spacers the car would simply never look clean again Ade |
