2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB MP LSD Fluid Change intervals
      03-03-2015, 09:42 AM   #1
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
What is the M Performance LSD fluid change intervals? Is there a break-in fluid change recommendation? Thanks.
///Sursum Ab Ordine
      03-03-2015, 08:44 PM   #2
mteele
Drives: 2015 M235i
It's a lifetime fluid according to BMW, with no break-in change
      07-23-2017, 12:08 AM   #3
madmax240
90
Drives:
So the MP LSD for the M240i doesn't have a service schedule?
I supposed, when the friction plates give out, it should then be serviced.
      07-23-2017, 01:08 PM   #4
Kolyan2k
920
Drives: 2006 S2000
Usually first change 1200 then every 30k
      07-23-2017, 03:00 PM   #5
MarcoZandrini
Drives: 2018 M240i
Does the M240i have an LSD?
Edit: owner's manual makes no mention of an LSD.
      07-23-2017, 06:13 PM   #6
Kolyan2k
920
Drives: 2006 S2000
LSD is a separate M-performance option on M235i. About $2k-2.5k I think
      08-03-2017, 11:46 AM   #7
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
As it were with the M235i. Port or dealer installed option.
///Sursum Ab Ordine
      08-22-2017, 08:08 PM   #8
Dylan86
Dylan86's Avatar
1330
Drives: F15d msport, F22 m235i
BMW "claims" a sealed lifetime service but I did mine @ 30k kms just because. Will do it again at 80-100k kms as well, along with the MT box.
      12-21-2017, 11:14 PM   #9
john16443
47
Drives: 2017 M240i
Recently installed the MP LSD on the M240i. I changed the fluid in my old E90 open diff easy enough. Is the fluid change in the MP LSD the same or similar enough to do yourself? I've read that partial disassembly is required!
      12-22-2017, 06:27 PM   #10
Dylan86
Dylan86's Avatar
1330
AFAIK, it's as simple as it "should" be. Drain via lower drain plug, then close the drain plug and fill via fill hole, and wait until it "overflows" ever so slightly. Put the top plug back in, whalaa?
I haven't done one on this car, yet, but I've done several on trucks and old model Audi's/BMW's and was as simple as above..
I could be way off left field, though..
      12-22-2017, 06:31 PM   #11
john16443
47
Drives: 2017 M240i
There is no drain plug on the BMW diffs. On the open diffs, you remove the fill plug and withdraw as much of the fluid by suction as you can. Then fill to overflow. It'll be interesting what you or I find on this one.
Dylan861330.00
      12-22-2017, 10:54 PM   #12
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Appreciate 2
cxp213313.00
Tpeterson156.50
      12-23-2017, 12:37 AM   #13
cxp213
cxp213's Avatar
313
Drives: M235i
Wow, what's the reasoning behind the lack of a drain plug?
      12-23-2017, 01:54 AM   #14
pikcachu
pikcachu's Avatar
1399
Same as the lack of dipstick
      12-26-2017, 04:20 PM   #15
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
As mentioned above: "lifetime" fluid. BMW says no need to change.
      12-27-2017, 11:34 AM   #16
cxp213
cxp213's Avatar
313
Drives: M235i
Just because they deem it "lifetime," it doesn't mean literally the oil can last forever.
      12-27-2017, 12:03 PM   #17
overcoil
3074
Drives: M235i 6spd
The old odd stories of the diy'er or service center tech draining the fluid then not being able to get the fill hole open.
      12-27-2017, 01:49 PM   #18
pikcachu
pikcachu's Avatar
1399
You can always flip the car over and the fill plug becomes the drain plug
      12-28-2017, 09:28 AM   #19
cxp213
cxp213's Avatar
313
Drives: M235i
Any half-wit would know to make sure you can access the fill hole before you even attempt at a drain hole, but maybe I give people too much credit.
But yeah, the fact that BMW doesn't want you to service the car anywhere except at BMW is probably why there's so many unnecessarily complicated or missing things.
      05-14-2018, 07:40 AM   #20
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
For what it's worth here's the Blackstone report from my 6MT in my 228i that had the "lifetime" BMW fluid in it for 71,321 miles. I changed it out and the diff fluid as well. No drain on the diff was a pain. If you change it out yourself make sure to be careful when you reinstall the rubber shock bumper/limiter bolt on the rear of the diff. Steel bolt/aluminum housing. I almost jacked it up and had to clean the threads up with a tap.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
2addicts
