TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Cobb Stage 1 Aggressive. AIR TO FUEL RATIO
      03-03-2015, 02:01 AM   #1
E92_Baker
E92_Baker's Avatar
18
Drives: 2013 335XI E92
Post Cobb Stage 1 Aggressive. AIR TO FUEL RATIO
Ive searched everywhere and can't get a concrete conclusion on this. Running a the stage 1 aggressive map. What should my ATF ratio be? At idle it's 14.7 which I'm almost positive is good. But at WOT its dropped to as low as 9.55 is that bad?? PLEASE HELP!! Normally when WOT happens its in the range of 10.5-13.25
Thanks in advance!
      03-03-2015, 05:37 AM   #2
proTUNING Freaks
proTUNING Freaks's Avatar
4496
Drives: powered by bootmod3
OTS maps have an issue on some cars where it will run richer than what the map targets causing misfires and loud popping out the exhaust through shifts. This is one of a number of things we address in our custom tunes. Let us know if any questions or if we can help. If you have a log of the issue feel free to email it to us for review support@protuningfreaks.com
      03-03-2015, 09:28 AM   #3
asrautox
19
Drives: 2011 335xi
Are you running a non-stock intake?
2011 335xi M-Sport | MHD E40 | VSRF DP/CP | Wagner IC | GFB DV+ | xHP Stage 3 | Dinan/Koni/UUC
      03-03-2015, 11:25 AM   #4
E92_Baker
E92_Baker's Avatar
18
Right I'm running a burger motor sports intake. Does that make a diffrence?
      03-03-2015, 11:26 AM   #5
E92_Baker
E92_Baker's Avatar
18
I will do a log today upload and send to you. Thank you so much!
      03-03-2015, 11:29 AM   #6
proTUNING Freaks
4496
Intakes used to be an issue but that issue is finally behind us and been worked out.
      03-03-2015, 03:56 PM   #7
Johnny Boost
324
Drives: '21 M850i GC
9.55 is not good but it doesn't surprise me that OTS maps aren't running optimally on your car. The Cobb AP isn't worth having unless you get a pro tune IMO. Are you running 93 octane btw?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      03-03-2015, 05:33 PM   #8
E92_Baker
E92_Baker's Avatar
18
Yes I'm running 93 octane.
      03-03-2015, 05:49 PM   #9
tke344
38
Drives: f15 X5 50i
I'd re-install the stock intake and do a few more logs, on the stock turbo it's a sound mod at best. The restriction at the inlet pipe is still there regardless.
      03-03-2015, 07:49 PM   #10
mike5809
mike5809's Avatar
Drives: '11 335i M-Sport [LeMans Blue]
I never got that low with an OTS map. I stayed at low 11s at high RPMs at WOT. I would start at usually at low 14s at low RPMs right after WOT and gradually go to 11s. That said I did sometimes dip into the 10s post shift just for a fraction of a second.
This was both with Stage 2 Aggressive and Stage 2+ FMIC Aggressive
      03-03-2015, 09:13 PM   #11
E92_Baker
E92_Baker's Avatar
18
Ya im gonna have pro tuning freaks pro tune it. It's worth it considering all get more power and it won't run rich.
      03-04-2015, 07:22 AM   #12
mike5809
mike5809's Avatar
Awesome - best of luck! I just got done working with Dzenno, it was a good experience. He is super prompt to respond to emails and provide new maps.
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks
'07 BMW 335i Coupe & BMW Z4 3.0i - Gone
      03-11-2015, 08:36 PM   #13
e92proper
45
Drives: 2011 e92 335 / 2013 X3
Dzenno works at PTF? Damn I need to talk to these guys.
Question about custom tune....if you go back to stock for dealer visit, the custom tune stays in the unit then you can upload again after dealer right? Sounds stupid, I was just checking
      03-11-2015, 09:03 PM   #14
MiamiM3
Drives: 2011 335i E90 AT M-Sport
It will stay in the Cobb AP and you will also have a copy on your computer that you can upload onto your AP.
      03-11-2015, 10:27 PM   #15
HP_HOUND
Drives: 2011 BMW 335i
Thanks in advance!
https://www.youtube.com/watch?v=9uFdrcPkMGE
Check this guy's video about A/F Ratio for the theory
Tags
cobb 335i, stage, tunning, turbo engine
