2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes F23 suspension options
      02-26-2015, 06:57 PM   #1
sirantsE90
sirantsE90's Avatar
149
Drives: N51 E90
2008 328i  [0.00]
So my dad took delivery of a F23 m235 today but I want to get shorter springs with higher spring rate for obvious reasons. I called h&r and they won't have anything for months. I have bmw checking if the coupe and convertible have the same part number for springs , which I highly doubt.
Has anyone come across suspension that will work for the F23?
Thanks guys
BMW CCA # 473001
      03-01-2015, 03:27 PM   #2
sirantsE90
sirantsE90's Avatar
149
Drives: N51 E90
2008 328i  [0.00]
I've done some more research and...nothing. Waiting on word if I can be the first set from H&R. Will update this for the convertible owners.
BMW CCA # 473001
      03-10-2015, 11:25 AM   #3
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Nothing yet
I will let you know as soon as new springs are released for your car
https://x-ph.com/sale/
Phone number 702-494-9435
      03-10-2015, 11:28 AM   #4
sirantsE90
sirantsE90's Avatar
149
Drives: N51 E90
2008 328i  [0.00]
Originally Posted by mike@x-ph.com
Nothing yet
Thanks. I have someone at h&r letting me know too. What companies do you offer?
BMW CCA # 473001
      06-17-2015, 11:26 AM   #5
sirantsE90
sirantsE90's Avatar
149
Drives: N51 E90
2008 328i  [0.00]
Okay so H&R has confirmed its the same part number. They are now selling the same H&R sports for both couple and convertible. They only tested on stock wheel and tire pkg so u with aggressive rear setup may be in for some surprise rubbing on dips.
ANY F23s dropped on these? How does the rear feel? What tire and wheel specs on you on?
also how much negative camber are you getting on stock F23 arms?
thanks all
BMW CCA # 473001
      06-17-2015, 11:28 AM   #6
sirantsE90
sirantsE90's Avatar
149
Drives: N51 E90
2008 328i  [0.00]
Okay so H&R has confirmed its the same part number. They are now selling the same H&R sports for both coupe and convertible. They only tested on stock wheel and tire pkg so u with aggressive rear setup may be in for some surprise rubbing on dips.
thanks all
BMW CCA # 473001
      06-19-2015, 08:51 AM   #7
sirantsE90
sirantsE90's Avatar
149
Drives: N51 E90
2008 328i  [0.00]
No one has experimented with maxing out the stock arms? If -1.5 is possible the H&R Sports should work with the aggressive rear specs.
BMW CCA # 473001
2addicts
