Headlight not working. Please help
02-24-2015, 02:29 PM | #1 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
Hello people,
I had my headlight not working so what I did for troubleshooting is: Swapped my xenon bulb to another headlight , was working Swapped my ballast to another headlight, wasn't working So I definitely knew that my ballast is gone and it's time for a new one. Today I bought a new ballast and had it installed on my headlight but the headlight didn't work First I thought it's a defective ballast so I switched it to another car and it worked perfectly, I switched my xenon bulb also was working perfectly. My question is: what could be the issue if both ballast and bulb are working perfectly but the headlight is not working ? I got the adptive headlight error on dash but that's not a reason for the headlight not to turn on I guess? PS: angel eyes working fine
02-25-2015, 12:07 AM | #2 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
Bump anyone?
11-09-2015, 03:45 PM | #3 |
34
Rep 715
Did you erase the tripped short circut error in tool32 ? If any faults are tripped you could get a electronic block in the FRM that you need to open before you will have power to your lamp again.
Search for tool32 and short circut erase Or look at this : http://www.e90post.com/forums/showth...=625111&page=2
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
