Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > heavy misfire-whats on my plugs?
      02-20-2015, 06:38 PM   #1
Dhillon92
82
Drives: '11 335xi
Hey, I've run into an issue with my 6mt e92 n55xi. I was on the highway to Niagara the other day cruising in 6th gear and decided to floor it, now usually this happens, it sputters for the first thousand rpm, sorta feels like the tiresate slipping, but they aren't. Anyhow, I know its a dumb thing to do while it sputters, but I did it anyway.
When I got to about 4000 rpm the misfire got worst and jerked the whole car in all rpms and all gears. Got limp, pulled over, restarted car, finished my drive with a lot of ease on the pedal. It would stop misfiring if I'm very light on it.
Trip ends, drive back same way, call up dealer to tow it, uninstall intake and tune. As I was deleting the codes I saw what had come up, was a misfire in cyl 4 and fuel control mixture code. (29e0) Problem still persisted and was misfiring constantly.
Also had changed spark plugs about 2000 kms ago, they were Bosch but not BMW branded ones, so I figured I'd swap the old ones back in as well. Turned out, the misfire is now gone with the old 50km plugs back in, but I still feel a misfire every now and again at idle.
While I swapped em all out, I saw some gunk in the plug chamber and *sorta* wet carbonish stuff on the plugs.
I've searched and have figured it is either coil or injectors, because I feel like if I put my jb4 back in and push it, I can replicate the problem, I just can't replicate it while car is stock, and am not sure what to present the dealer with now.
Attached are pics of the gunk in my chambers, what is that stuff?
Thanks for the feedback!
      02-20-2015, 10:39 PM   #2
weehe126
1161
Drives: 2017 340i
Looks like a leaky valve cover gasket. Which in turn fouled up your new spark plug.
      02-21-2015, 02:41 AM   #3
hailpersia
hailpersia's Avatar
72
Drives: 2022
odd, I started experiencing the same thing on Cobb after the VANOS recall. no codes and only on Cobb. going to change plugs this weekend.
      02-21-2015, 04:16 PM   #4
Dhillon92
82
Drives: '11 335xi
Interesting, I have also found oil sprayed onto my intake pipe and near my coolant tank. Might very well be a VCG!
      02-21-2015, 09:46 PM   #5
weehe126
1161
Drives: 2017 340i
That is probably from the oil filter housing gasket/oil cooler gasket. Looks like you have a few gaskets to change lol.
      02-22-2015, 10:14 AM   #6
sy2767
sy2767's Avatar
145
Drives: 2013 x5
How is that possible? LOL. Do you realize it's impossible for a leaking valve cover to foul a plug? Not trying to be rude just stating the truth. I would also like to add that the spark plug looks ok to me, I don't see a cause of the misfire by looking at that picture. The "gunk" in the pic is just a little seepage of oil from the valve cover gasket, I would put some spary 9 or other grease-oil cleaner on a rag and clean it off, check it again in a few weeks to see if it returns. I certainly wouldn't replace the gasket if thats all it's seeping.
      02-22-2015, 12:05 PM   #7
Chocolatethunder
Drives: E92 335i
If you have bad injectors, possibly 1 stuck open this would definitely cause your spark plugs to be gunky. You can check and see if you smell gas coming out of your exhaust pipes. But injectors cost more but if you are running a JB it will exploit your fuel system and find weak points so you will eventually need to do coils as well as wallnut blast. This combo will have your car running smoothly.
      02-23-2015, 03:12 PM   #8
Dhillon92
82
Drives: '11 335xi
Thanks for all the feedback guys! Cars going into dealer tomorrow I'm going to point these things out to them and let's see what they replace. Will keep thread updated!
      02-23-2015, 06:09 PM   #9
weehe126
1161
Drives: 2017 340i
If he had an N54...
      02-25-2015, 03:19 PM   #10
Dhillon92
82
Drives: '11 335xi
So BMW got back to me, replaced an oil line leaking, couldn't replicate my misfire since most of it is gone after switching back to stock plugs... Considering the jb4 isn't in they wouldn't be able to push it beyond stock limits anyway. So for now I'll just leave my stock plugs in, mod it back up, install my new catless downpipe and say goodbye to the dealer for a while!
On a side note: I got a 328d 2015 as a loaner with 9km on the clock, not bad!
