02-17-2015, 05:37 PM | #1 |
BimmerPost Supporting Vendor
9546
Rep 10,844
IND Presents: Fall Line Motorsports Adjustable Sway Bar Endlinks
Height adjustable dampers are required in order to properly corner balance a car, enabling the alignment technician to set each height individually, cancelling out any uneven crossweights. In order to complete the job, however, adjustable sway bar end links are also a must. Uneven loading of the sway bar will send forces through the bar and into the suspension at static ride height, and worse yet the bar will reach a “zero load” point somewhere in the suspension’s travel, usually at an unknown and inopportune moment. For this reason, adjustable sway bar end links are an absolutely critical component for anyone who is serious about extracting the best possible handling from their M car. By varying the length of each link slightly, the alignment technician can ensure that the sway bar is completely unloaded and unstressed at static ride height, giving the car excellent chassis dynamics and truly even corner balance. The adjustable sway bar end links by Fall Line Motorsports are constructed with top quality bearings, and billet machined heims. Dust boots seal the end links and prevent dust from interfering with operation. Please contact an IND representative for more information! FALL LINE MOTORSPORTS F8X M3 / M4 SWAY BAR END LINK KIT may be viewed at the following link to our online store: Front: https://ind-distribution.com/product...LM-F8x-1BFLINK Rears: https://ind-distribution.com/product...LM-F8x-1BRLINK Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com Read more about IND and our family of brands here!
