Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Auto Tranny Sluggish
      02-12-2015, 06:00 PM   #1
shatter2
Drives: 2008 BMW 335i AT
Question Auto Tranny Sluggish
I have an '08 335i with the automatic transmission and it has been getting sluggish over the last 6 months. It has slowly gotten worse over time until I finally broke down and did an automatic transmission service (new pan/filter, new fluid, new fill plug). I did not drain the torque converter but was able to replace about 4L of the fluid.
At first I thought the new fluid helped (Redline AT4) but I was wrong. It is especially bad early in the morning in the first 2 minutes of driving the car. It will not downshift to 2nd gear for stop signs sometimes, which causes the engine to kind of lurch and buck. Also, until it fully warms up the operating temperature it will sometimes lazily upshift, which also lurches the car after it finally engages the new gear.
I don't know what the problem is. Any suggestions would be helpful.
      02-12-2015, 06:07 PM   #2
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
Auto trans are so complex these days that chasing a problem out of 1271 components will be pointless
cheap low mileage auto trans are readily available, just swap to a different one
http://www.car-part.com/
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      02-13-2015, 08:36 AM   #3
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
Before you get up and buy a replacement 6AT, try resetting the adaptations with a BT tool. I had similar issues, and resetting the adaptations resolved them.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      02-13-2015, 09:51 AM   #4
shatter2
Is that something that is possible with the JB4 or would I have to have the actual Bavarian Technic tool?
      02-13-2015, 10:27 AM   #5
CHECKERED
ex deus machina
CHECKERED's Avatar
Need the BT tool, it’s under $200 and you can do back end flashes if you have a JB4,
But what you are describing sounds like a mechanical fault not a software issue.
Doesn’t hurt to try
      02-13-2015, 10:37 AM   #6
PR3CI5N
need4speed
PR3CI5N's Avatar
Drives: 2010 E90 M 335i
Do you have the Alpina TCU flash?
N54
      02-13-2015, 03:16 PM   #7
shatter2
Thanks for the feedback guys. I will look around to see if there is someone locally that I could borrow a BT tool from.
I don't have the Alpina flash but I want to get it done. I'll look into that as well. Thanks!
Tags
automatic, lazy, lurch, shifting, transmission
