TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Cleaned valve cover in safety-kleen, inside changed color. Oxidization?
      02-12-2015, 02:37 PM   #1
desolatax
9
Drives: '14 328d xdrive
I'm doing my metal (Aluminum? magnesium?) valve cover gasket on my 2006 330xi, and I cleaned it at a shop with a Safety kleen solvent based cleaner bin, then hosed it down with water and let it dry in a heated room overnight.
The next morning I looked at the cover and it changed color from what it was after I had cleaned it.
Since it changed color, does it matter? Is it oxidization? Did I ruin my cover with using the solvent?
The part was closer to what the edge looks like on the second pic here.
View post on imgur.com
      02-12-2015, 03:31 PM   #2
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Probably.
      02-12-2015, 06:02 PM   #3
hassmaschine
Drives: "NBO" 330i
it's magnesium, it's highly corrosive and reactive.
      02-12-2015, 08:24 PM   #4
avocet
252
Drives: 2007 328i 2011 X5d
Magnesium usually has a chemically induced oxidation layer to prevent further oxidation. This layer is quite pourous and when degreased with a heavy degreaser or chemicals it will turn whitish.
      02-12-2015, 09:30 PM   #5
RemovedUser
Guest
n/a
Drives:
Don't worry about it, it looks fine, just wipe it down with brake cleaner on the mating surfaces and install it.
Its just oxidation.
