Big thanks - Makkan
02-07-2015, 08:59 AM | #1 |
16
Rep 224
Big thanks - Makkan
Over two years ago I spent a lot of money at Audiofile - http://www.audiofile-incar.co.uk
Since then, pretty much every time I have driven my car it's annoyed me that my stereo did not sound as it should. The parts and installation were good, arguably the sub wasn't ideal for my boot and i've changed it and if you are going to fit a digital EQ you should know how to set it up.. but anwyay. I spent a while trying to sort this myself, but lack of knowledge / time / basis to gauge progress against meant I was unable to do this to the right level. On thursday I met with Makkan, and in about two hours he was able to fully tune and set everything up, and it now sounds amazing, for the first time in years I take the long way everywhere, just so I can enjoy it. Mak, I made two minor changes to your config, drop fronts by 1db on the bit-ten and set sub to normal phase, this has made it sound the same as what we sampled when the vehicle was stationary, when moving.. And a tiny bit more bass - overall though I am over the moon.. Thanks Bud |
02-07-2015, 09:32 AM | #3 |
30
Rep 226
I hadn't heard of these upgrades before. Could you tell me which upgrade path of theirs you took? Do you have any pics of the door speakers/tweeters. I seriously tempted by this
02-07-2015, 09:44 AM | #4 |
Rep 49
02-07-2015, 10:21 AM | #5 |
16
Rep 224
My recommendation would be save yourself 1.5K and buy what Makkan recommends and get him to fit & tune.
For reference, I have the full package, but diff sub than what they recommend. Focal KRS 100 4" Components Earthquake Underseats JL Audio W6 12" 2x JL Audio Amps 1x Bit Ten There are various options around - perhaps see if you can go to a meet and listen to a few different types, as that way you know what you can have before shelling out. I think I have spent 3.5K when realistically I only needed to spend around 1.5k-2k? if I had known at the time... If anyone is reasonably close I'm happy to show you what I have.. |
02-07-2015, 12:12 PM | #6 | |
886
Rep 9,097
Good to hear that you tweaked it bit further. Thanks
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
02-07-2015, 12:31 PM | #7 |
30
Rep 226
Maybe I've misunderstood their pricing structure but I was under the impression that their system 3 which consists of:
Focal components JL audio amp 2x 8inch subs For £1500 fitted? That seemed to represent quite good value for money I thought |
02-07-2015, 12:45 PM | #8 | |
16
Rep 224
Top stage from them = Focal components JL audio amp x2 2x 8inch subs 1x 13" Sub 1x Bit Ten Works out at 3k, then factor in buying a different sub, in my case JL Audio W6 £500 inc a stealth enclosure.. |
02-07-2015, 12:59 PM | #9 |
67
Rep 1,431
Makkan's had more business than half the south east dealers! Just goes to show what great customer service can do.
If I was a dealer or an indi in that area, Sam would be on the payroll by now! Assuming of course I could afford him. Top work fella. WM |
02-08-2015, 04:58 AM | #10 |
886
Rep 9,097
Thanks for your kind words mate.
02-08-2015, 07:03 AM | #11 |
30
Rep 226
Hi Mak,
Could you tell me what sort of cost I would be looking at for an audio overhaul? I currently have BMW HI-FI option with CIC nav on a 2010 LCI E92. I would like to have the front components upgraded and door cards sound deadened, underseat subs upgrade along with associated amp and processor installed. I have obviously seen the Audiofile upgrade discussed by the OP above, but happy for you to suggest alternative options if you think there is better equipment out there. I would like to retain OEM looks as much as possible so not interested in having a larger boot mounted sub etc. I am however interested to hear your thoughts on upgrading the rear co-axial speakers at the same time. Thanks, Russ |
02-08-2015, 09:08 AM | #12 | |
886
Rep 9,097
Depends on what you are after. If you are after sound quality then MS-8 sound processor XD 600/6 Amp Morels door speakers / Gladen kit Earthquakes under seats / Gladen under seats Morel or Focal central speaker BMW logic 7 / individual speakers at rear This will give you extremely well balanced and quality sound. Better than bmw logic 7. If you are after SPL (loud sound) then Audison bit one and keep the rest of the drivers as they mentioned above. You can have some idea by looking at the prices of these items that how much will that cost. HTH. PS: We have disregarded sub boot.
02-08-2015, 12:11 PM | #13 |
344
Rep 6,176
Sam,
Need to get down and see you for some TLC to tuning my car soon please. Let me know your diary for March |
02-08-2015, 01:34 PM | #14 | |
30
Rep 226
Is it generally considered necessary to run in new speaker cables or do people run their new components and underseat subs from the OEM BMW wiring? |
02-15-2015, 03:01 AM | #15 | |
16
Rep 224
If you are local your welcome to listen to mine and see what it should sound like and we could copy the settings over. I am in Colchester Essex Otherwise maks your man and will fix the sound. |
02-16-2015, 10:05 AM | #17 | ||||
886
Rep 9,097
When you are ready, get in touch. Quote:
re: wiring: You use your current speaker wirings. Exception is underseats and for that you run new wires to low pass them. Quote:
But if any of his amp is setup at different gain settings, then your settings may damage his drivers. Lets say your gain is 20% on sub, where his is set at 30%. So your settings will run his sub with clipped sound. Give it 30 minutes and you will have a cooked sub! Quote:
Thanks for the kind comment. Looking forward to see your project finished.
03-02-2015, 06:28 AM | #18 |
26
Rep 250
Another Makkan recommendation here.
Met with Sam yesterday to tune my system and he's really made it sing. Massive difference to how it was setup before. Thanks buddy and see you soon for the dash cam install! |
03-02-2015, 09:26 AM | #19 | |
886
Rep 9,097
In all honesty, when we compare setting A and setting B, difference was massive. For others who read this, Setting A was setup by me and Setting B was setup by other company (refrain to mention name), and I cannot beleive how these guys let your car out of their garage. Glad that it worked out well for you mate.
03-05-2015, 10:52 AM | #20 | |
16
Rep 224
03-05-2015, 11:43 AM | #21 | ||
886
Rep 9,097
03-06-2015, 02:45 AM | #22 |
93
Rep 1,568
Am Visiting the 'Big Man' next weekend. Sam is continuing his great work on my car! Can't wait.
Only down side is that i have talked up Lakeside shopping complex so much my Darling Wife wants to come. Might just loose the credit card in Ireland this weekend, i'll leave the pin number attached to it!! The finder will spend less than my wife will next weekend!!!!!
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you" |
