05-13-2015, 07:12 AM | #2 | |
37
Rep 40
I do have a work around. Program the seat memory button 1 with the get in or out of the car setting (seat all the way back). Program seat button 2 with your perfect driving setting (seat positioned the way you like to drive). Now, open the driver side door with the ignition off. Push button 1 or 2. The seat auto adjusts without having to hold the button! Once the seat is positioning itself, you may shut the door and turn on the ignition and the seat will continue to adjust. However, if you put the car in gear, the seat stops adjusting. Sometime if the car has been in the off position for a long time, when you press the button 1 or 2 with the driver side door open, the seat does not move continuously. Press the brake peddle firmly and then press the button once again. It will then auto position. Remember, the key is the driver side door must be opened and the ignition off when you begin to adjust your seat. Hope this helps. |
11-25-2015, 11:12 AM | #3 |
523
Rep 1,105
11-25-2015, 11:27 AM | #4 |
Ninja
390
Rep 4,014
yes there is, alex@alpine coded this very feature for me...sorry don't know the actual module or code but just wanted to confirm this feature is possible...
seats slides back a few inches at engine shut off, upon returning to vehicle: with door closed and electronics turned on the seat will slide forward the same distance it traveled in reverse...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
11-25-2015, 11:34 AM | #5 |
920
Rep 1,481
All you have to do is : take a look at this thread.
2015 Mineral Grey ///M4 6MT
11-25-2015, 12:16 PM | #6 |
523
Rep 1,105
This isn't the first time you tell me to use search but believe me I have how else did I get here? So either something is wrong with the mobile site or the search sucks but ni matter what keywords I search on.
For example this is the crap the search gives me when I search on force brake flashing: http://f80.bimmerpost.com/forums/sea...rchid=41896987 So I don't know what I am doing wrong. |
11-25-2015, 12:25 PM | #7 | |
920
Rep 1,481
Anyhow, this one was admittedly tricky, since the title of the thread is not very suggestive: it is easier if you know that BMW calls this feature "Easy Entry". BTW, did I really tell you to use the search before?
11-25-2015, 12:51 PM | #8 | |
523
Rep 1,105
Next on the list is the force brake flashing coding. I want to enable it at lower speeds and faster meaning at a lower deceleration. |
11-25-2015, 01:17 PM | #9 | ||
920
Rep 1,481
11-25-2015, 01:28 PM | #10 |
523
Rep 1,105
Figured out how to move the seat further back and tomorrow I will give the force brake flash parameters a try.
11-26-2015, 08:36 AM | #12 | |
523
Rep 1,105
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = "Modus_FA_SLV" 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C |
11-27-2015, 12:35 AM | #13 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
The easy entry feature should be something programmed from the factory. Why does BMW cut these features out? Ridic!
/// M3 |
11-27-2015, 03:29 AM | #14 | |
523
Rep 1,105
With EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS you specify how many milimeters of free leg space you want to keep for the passengers sitting on the back seat. So basically you can set EAH_VERFAHRWEG_SLV_PHYS to Werte=00, FF which is then move the seat back with 25.5 cm (imho the maximum) and then play with the EAH_SCHUTSFREIRAUM_HINTEN_SVL_PHYS setting. This has the advantage that no matter how far your seat is set, that the seat will be moved back the maximum number of milimeters but always respecting the free leg space for the passengers in the back. And converting hexadecimal to decimal and vice versa can for example be done here: http://www.binaryhexconverter.com/he...imal-converter Last edited by G4BR13L; 11-27-2015 at 03:44 AM.. |
11-29-2015, 02:16 AM | #15 |
523
Rep 1,105
I guess that the SM2(D6) module is for the driver side and the SM2(E6) for the passengers seat. Can someone confirm this and I would to know if we can enable easy entry/exit for the passengers seat.
11-29-2015, 08:59 AM | #16 |
523
Rep 1,105
To answer my own question I set EINAUSSTIEGSHILFE in the SM2 (6e) module to werte=03 and now the passenger seat also returns to the last position.
02-07-2016, 11:28 PM | #18 | |
116
Rep 399
Rob - rcw119
- 2016 F82 - 6MT - Sakhir Orange - 2014 E84 xDrive28i - Valencia Orange - 2008 E92 335i - 6MT - Sparkling Graphite (Retired) |
01-20-2018, 05:21 PM | #19 |
42
Rep 61
I got my 2014 X5 35i programmed to move the seat all the way back, but how about programming it it go all the way down (for easy exit)?
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package |
08-09-2022, 10:58 AM | #20 |
82
Rep 175
Is it possible to deactivate or just the passenger seat? BimmerCode doesn’t have an unassigned value option, only active. Any help with the expert coding is appreciated.
