Name and Shame - http://www.bmwnavi.co.uk
01-28-2015, 08:34 AM | #1 | |||||||||||||||||||
Rep 29
So I decided to order a replacement updated DVD for my Sat Nav on my e90. I used www.bmwnavi.co.uk which turned out to be a disaster. I don’t normally post this sort of thing but hopefully it will help other members and make you chuckle like I did. Its a shining example of how you should not treat a paying customer. Its probably a little childish of me but i have copied and pasted every email exchanged between us below just so everyone can get the full story and not just my side of the story.
23/10/14 - Placed Order 6/11/2014 - The purchase confirmation email states your "order will be shipped in 1 business day".... 2 weeks later and still no sign of the disk. I sent an email to enquire about it. Quote:
08/11/14 – Email sent. Quote:
12/11/14 – Another email sent Quote:
04/01/15 – Email sent - Quote:
23/01/15 So I waited more and no sign of the replacement. Email sent - Quote:
Maybe there is a problem with my Sat nav but its unlikely as the old OEM BMW disk works fine and never once gave me a read error and even if there is a problem then the seller should advise me to check it out. Obviously if my sat nav worked fine with the old disk I am going to assume that the issue is with the new disk. And can anyone recommend where i can get a replacement disk that will actually work?
Current: On my bike
Past: 1.6 Mk4 Golf, 1.6 A3, 320ci, 323ci, 330ci CS, e90 335D, 67 Mustang "Eleanor", C63 AMG PPP Last edited by JohnnyMustang; 01-28-2015 at 08:44 AM.. |
01-28-2015, 09:48 AM | #3 |
23
Rep 386
It is possible your dvd drive is faulty. It's a common problem and starts as intermittent then becomes more persistent. Mine did this and funnily enough the copy dvd navigation discs would show the error more often but eventually the OEM ones fail to read too. OEM discs do seem better quality.
If you have anyone in your area to check the disc I would try that. The DVD drives do tend to fail around the 4 year old mark from memory and BMW have reduced the price of the drives considerably since it became such a common complaint. Its about £90 and fairly easy DIY. He probably should have mentioned this earlier and been a bit more polite as its a well known issue. I would run the OEM one for a good month to prove its not the drive. If it is failing it should show read errors within that time |
01-28-2015, 09:56 AM | #4 |
Rep 29
There are many expensive things i don't mind paying money for but £180 for a DVD from BMW is not one.
Current: On my bike
Past: 1.6 Mk4 Golf, 1.6 A3, 320ci, 323ci, 330ci CS, e90 335D, 67 Mustang "Eleanor", C63 AMG PPP |
01-28-2015, 10:01 AM | #5 | |
Rep 29
I will put the OEM dvd back in tonight and it will be interesting to see if i get any faults. My car is 2008 so there is a chance that it is causing the issue but funny that is only started giving trouble at the exact time i put the new DVD in.
Current: On my bike
01-28-2015, 10:15 AM | #6 |
23
Rep 386
It's worth a try. I think it's the damper that seizes and perhaps it was running ok but ejecting and loading a new DVD was enough to unsettle it and its now sticking a bit. It has done well lasting 7 years if its the original though.
IF it is the drive here's a DIY. Looks dramatic but it's not too hard. You can see how much BMW used to charge £380!!! http://www.e90post.com/forums/showthread.php?t=346876 |
01-28-2015, 10:18 AM | #7 |
39
Rep 133
Could be cheap quality DVD's / burnt incorrectly. Do you know what brand DVD they are? The only make that I could get working in my CIC was Verbatim burned at a very slow speed, all other brands would throw up read errors.
Have seen this website a few times, will avoid purely due to the sellers bad customer service. |
01-28-2015, 10:25 AM | #8 | |
197
Rep 3,500
01-28-2015, 10:44 AM | #9 | |
9
Rep 272
01-28-2015, 10:48 AM | #10 | |
Rep 29
Current: On my bike
01-28-2015, 12:02 PM | #11 | ||
197
Rep 3,500
01-28-2015, 12:29 PM | #12 | |
Rep 45
01-28-2015, 02:18 PM | #13 |
115
Rep 316
Drives: 2018 F31 340i Shadowline Ed
Another vote for Rusty. Got the 2015 DVD for my CCC and so far so good.
Previous: 2007 E91 330i M Sport (Titan Silver)
Current: 2018 F31 340i Shadowline Edition, MPPSK, (Alpine White) |
01-28-2015, 06:45 PM | #16 | |
Rep 115
01-28-2015, 06:56 PM | #17 | |
7
Rep 162
I've also bought discs from here without problems, gonna try the 2015 dvd |
01-29-2015, 12:50 AM | #19 |
13347
Rep 7,484
At first I laughed but then I was like what a toss pot... how can you expect business if you piss off your customers? Good job on making a thread so we know who not to contact when it comes to these matters.
01-29-2015, 10:16 AM | #20 | |
Rep 115
01-30-2015, 03:57 AM | #22 |
7
Rep 313
Just to add my two pence worth - I got one from Rusty and it worked for a few weeks but then I got the same errors the OP was getting that required me to eject the (incredibly hot) disc wait until it had cooled down to put back in and repeat the process every 10-15 mins. In the end I just reverted to the OEM one which has caused me no problems whatsoever.
The main reason I got Rusty's was for the speed cameras but learned they are only visual and not audible alerts and they are accessed as a POI which means you can't find others with them on the screen! |
