N55 2C71: Charge air pressure sensor: pressure too high
01-23-2015, 05:48 PM | #1 |
3-pedaler
7
Rep 39
I have a 2011 N55 335i, 4/10 build date, 16k miles (long story). I am getting the SES light / half engine indicator, reduced engine power etc. message. My BT reads out 2C71 Charge air pressure sensor: pressure too high. The car has no unusual symptoms; it drives fine although I haven't tried any WOT.
No obvious physical indicators or weird noises under the hood. I cleared the code...start the car up once, its fine...start the car a second time the SES light / half engine indicator and the 2C71 code returns. Any ideas what may be causing charge air pressure to be too high? Bad wastegate? Thanks for any thoughts... |
01-23-2015, 06:13 PM | #2 | |
28
Rep 583
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
01-26-2015, 07:40 AM | #6 |
16
Rep 168
Sounds like a wiring or sensor issue if it sets that quickly. Have you inspected the boost sensor/wiring before the
throttle body?
2012 335is DCT - JB4 - MHD - Fuel-it! - DocRace
01-26-2015, 06:53 PM | #7 | |
3-pedaler
7
Rep 39
Thanks for taking the time to post. |
01-26-2015, 08:06 PM | #8 | |
16
Rep 168
02-19-2015, 04:44 PM | #9 |
3-pedaler
7
Rep 39
Following up here...it took the dealer three weeks to figure it out (!!), but the problem was caused by a faulty intake air pressure sensor. rhm135 you were right on the money . Dealer replaced the sensor (part # 13-62-7-585-493).
Tags |
2c71, n55 |
