F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > replacement wiper blades
proTUNING Freaks
      01-23-2015, 12:04 AM   #1
canbmw
15
Drives: 2014 F31
Is anyone using aftermarket wiper blades? I have had two sets of the BMW ones on my F31 and they are not good. In particular there is a big streak on the driver's side right in my field of vision. I actually wonder if there isn't enough pressure at the mounting point or something.
The Michelin ones at Costco require you to order 'special hardware' afterwards to install. I have also seen Valeo and PIAA ones available online but can't find any locally.
Any ideas?
      01-23-2015, 07:03 AM   #2
Jackamie
Drives: F30 328i Black on Black
I have an F30 328I, and got Bosch aftermarket replacement blades. I wont be back to Canada until beginning of March to tell you which model. I paid under $40 and they work great.
      01-23-2015, 07:39 AM   #3
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
The BMW ones are crap, I had to replace my drivers side one when the car was only a month old, for the same reason as the OP. Replaced it with a Bosch one and it's loads better. Never bothered with the passenger side one, but the missus always complains that the screen is dirty her side because of the rubbish BMW wiper.
      01-23-2015, 10:00 AM   #4
spuntyb
spuntyb's Avatar
Drives: 2019 F90 Competition
The Bimmer wipers blow. I get a set of these every 4-6 months:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Amazon may say they don't fit your F31, but they fit mine perfectly.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold)
2018 F80 ZCP TB|SS (sold)
2015 F30 335 AW|CR (sold)
2015 F31 MG|CR (sold)
2011 E90 JB|Oyster (sold)
      01-23-2015, 03:05 PM   #5
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
I felt the OEM wipers on the F30 were flimsy and didnt work well from day one. I finally grabbed a set of RainX Latitude blades and am absolutely amazed by them. Honestly I never knew aftermarket wiper blades could make such a difference.
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      01-23-2015, 03:06 PM   #6
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Holy crap those are some pricey wiper blades! To be fair, if the windshield is too dry the RainX Latitudes can squeak a little, but i would think even these bad-boys would do that on a dry windshield.
Current: 2021 340xi
Retired:
      01-23-2015, 05:22 PM   #7
canbmw
15
Drives: 2014 F31
Thanks for the feedback! I will look around for the Bosch ones - maybe Canadian Tire??
      01-23-2015, 06:19 PM   #8
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
I've Tried the RainX Latitudes on my SUV and i don't think they are that great.
1) after 120kmph it doesn't wipe the whole windshield. the edges get lifted up by the wind i guess.
2) they are terrible when mixed with road salt. I have to use so much windshield fluid to keep it wiping smooth and not causing any squeaky noises.
As for Bosch wipers...from what I've read Bosch makes the BMW oem wipers
Canadian tire doesnt carry them. but part source does.
Canadian tire gets all their parts from part source though.
I've never had any issues with my OEM BMW wipers, had them on both my E90s for the 3 years each with no problems.
Even my current F30 its been 2 years and i dont have any issues with it
      01-24-2015, 04:15 PM   #9
Orion4
Drives: 2013 335i Sport Line Sedan
I use Bosch Icon blades: 24-OE & 19-OE. Work fine for me.
      01-24-2015, 05:32 PM   #10
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
Not sure about F3x sizes, but the Bosch Icon blades are available at Canadian Tire, I recently picked up a set there for a family member's car.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      01-25-2015, 02:06 AM   #11
canbmw
15
Drives: 2014 F31
Do the Bosch Icon ones come with the proper hardware for installation?
      01-25-2015, 02:18 PM   #12
overkill1125
overkill1125's Avatar
130
Drives: 2019 440xi Gran Coupe
Want to know also?
      01-25-2015, 03:37 PM   #13
CHCCubs
CHCCubs's Avatar
Latvia
97
Not sure about the F3x ones, but the ones I mentioned above for another car (Kia) did come with everything needed to install.
      01-26-2015, 10:38 AM   #14
Orion4
Yes! Bosch includes several other adapters, but none is needed. The blades fit on without any adapters.
      01-26-2015, 12:21 PM   #15
wtzouris
Drives: 2014 328d xDrive Sports Wagon
Orion4 you are right! Bosch 24OE and 19OE work great, they are a good value if you buy from (Amazon). I want to try the PIAA ones too but I needed a driver's side wiper today so I went to AutoZone and paid a few dollars more for the Bosch 24OE. For the 2014 F31 Sports Wagon you have to take the clip that is attached to the new 24OE wiper blade off-- then you install it as is without any adaptor. You end up with 3 extra plastic parts from the new blade.-- 2 extra clips plus the one you have to take off.
      01-26-2015, 12:49 PM   #16
wtzouris
I found another option for the F31 Sports Wagon, a little less pricey than the PIAA 97370 Silencio X.trm Silicone Wiper Blade - 24"/19", Pack of 2 ($84.99 on Amazon)
Here is the PIAA page for them:
http://www.piaa.com/store/c/32-Si-Tech-Flat-Blade.aspx
And here are the prices: (Individual) Total for 24"/19" is $54.52
PIAA Silicone 97060 Si-Tech 600 mm Part 81 (24 inch) $29.04 on Amazon
PIAA Silicone 97048 Si-Tech 475 mm Part 8 (19 inch) $25.48 on Amazon
      01-26-2015, 01:35 PM   #17
Earthmaster
127
Drives: 15' M4 Austin Yellow
used Rain X ones.. worked great.
      01-27-2015, 12:40 PM   #18
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
can you guys share link for rainx wipers.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      01-28-2015, 01:18 AM   #19
dreamspeed
dreamspeed's Avatar
Drives: 6MT
But the BMW replacements are free
      01-28-2015, 06:48 AM   #20
spuntyb
spuntyb's Avatar
Isn't that only once per year though? Might suit many people, but I like to get new about twice a year, sometimes more, depending on wear and tear.
      01-28-2015, 10:05 AM   #21
Orion4
Yup! Annually- unless you can show that it is failing- streaking/chattering. I do the same and change at the 6 month mark between annual replacement by BMW. My "old" eyes like a clean/clear windshield !
      01-30-2015, 06:32 PM   #22
CHCCubs
CHCCubs's Avatar
Latvia
97
Sadly not here in Canada
f30post
