BIMMERPOST Universal Forums Off-Topic Discussions Board    Garage Flooring System - Questions
      01-20-2015, 10:10 AM   #1
Former USMC
Former USMC's Avatar
Drives: 2013 335is Crimson Red
Greetings,
Was wondering if anyone has installed a Swisstrax Ribtrax flooring system in their garage?
http://store.swisstrax.com
1. How do you like it?
2. Easy to keep clean?
3. Resist tire marks?
4. Does the floor take longer to dry after parking a wet car on it?
5. Any breakage?
6. How to you manage dirt, dust, and other debris?
7. Desired or preferred colors or patterns?
8. Would you do it again?
9. What other options did you consider? Paint, vinyl, etc?
Thank you for your response. Other comments are welcomed.
Semper Fi
      01-20-2015, 10:15 AM   #2
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
I have Racedeck in mine, but I doubt it's much different from Swisstrax.
1) I like it
2) I blow it out with a leaf blower, or sweep it. If the tiles get dirty, I just clean them with APC
3) yes, no tire marks
4) the Racedeck tiles have little channels under them, which is supposed to aid with the draining of water. But if your garage is 100% leveled, then the water might just sit on or under the tiles
5) zero breakage
6) just like anything else, just vacuum it, sweep it, use a leafblower, etc.
7) personal
8) I would
9) considered epoxy
      01-20-2015, 10:27 AM   #3
Former USMC
Thanks for the great and speedy response. Your garage looks great by the way. I appreciate your comments.
      01-20-2015, 11:59 AM   #4
Joekerr
7929
Drives: 2017 Audi S6
I think Mr. Tonka (Joe) installs floors. Or did. Seems to know something about them. He'll probably have some good advice.
      01-20-2015, 12:18 PM   #5
P1
P1's Avatar
11572
Oh, and don't get white tiles unless you enjoy cleaning them a lot. They just get dirty. Looks amazing when clean, but let's face it: white will just get dirty IMMEDIATELY in a garage.
      01-20-2015, 12:34 PM   #6
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
Not really for system floors. We do permanent installation items. Only stuff we've installed in garages is granite, porcelain, and epoxy.
Most of the dealerships we do use porcelain tile these days. Granite is too expensive and porcelain is non-porous enough (dense) to handle the vehicle weights these days.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      01-20-2015, 01:27 PM   #7
Joekerr
7929
Ahh, I see, noted for next time.
      01-20-2015, 03:43 PM   #8
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
Epoxy available for DIY worth the trouble?
      01-20-2015, 03:46 PM   #9
128Convertibleguy
60
Drives: 2010 128 Covertible
Smile
Like any paint job, it's all in the prep work
      01-20-2015, 03:47 PM   #10
UncleWede
UncleWede's Avatar
Generally, there's paint from Lowes, and then there's PAINT.
      01-20-2015, 04:11 PM   #11
P1
P1's Avatar
11572
Look at the paint they use in warehouses, and then apply the same stuff in your garage at home. Commercials/industrial stuff should hold up.
      01-20-2015, 05:47 PM   #12
Mr Tonka
Mr Tonka's Avatar
THIS.
Do most people do this just for aesthetics or for function? If for function, what function are you looking for the floor coating to perform?
      01-20-2015, 10:20 PM   #13
zx10guy
5150
Drives: 2013 135i
I did the epoxy paint on my garage floor. Followed the prep after power washing the concrete floor. Painting was straight forward. Just mix the two cans together to make one gallon. Rolling the paint was a bit of work as the epoxy rolls on thick. Needed 1.5 gallons for my 2 car garage. I also was able to do the epoxy before anything contaminated the floor because I bought my house brand new from a builder.
The flooring lasted about 3 to 4 years before it started peeling. I read somewhere this could happen with a cold floor and warmed up tires sitting on top of the epoxy. It's been about 13 years, and there are about 4 spots where the paint has lifted off entirely where the tires of my cars were sitting on.
Next go around I'd probably consider doing tile instead of epoxy.
As for why I did this, it was more for the functional aspect. I used to wrench a lot. As a result, lots of junk gets on the garage floor. It's real nice to be able to just wipe up the mess off the floor, hose off the area, and then squeegee off the floor. Anyone who has spilled motor oil onto a porous surface like concrete knows what I'm talking about.
      01-20-2015, 11:25 PM   #14
radix
you know he kills little girls like you
radix's Avatar
388
Drives: -
I pooped on my garage floor. It smelled delicious. Wait, what was the question?
      01-21-2015, 11:11 AM   #15
128Convertibleguy
60
Smile
There's good stuff and bad stuff everywhere. Lowe's Valspar "bonding primer" has worked very well for me in providing a base layer. It sticks well to many things, including glossy paint, and seals and hides well, too. Pretty low odor. It has saved me a whole lot of work.
      01-21-2015, 01:05 PM   #16
Former USMC
zx10guy,
Thanks. I too, started with epoxy (about 10 years ago)...had one car that peeled the paint up and have been retouching ever since (and no, it does not last very long)...thought it might be time for a replacement.
I met the Swisstrax company in Scottsdale (Barrett Jackson) and was impressed with their product. The installation seemed fairly easy and straight forward with little to NO prep. Comes in a variety of colors and reasonably priced.
Thanks for your feedback.
Semper Fi
      01-21-2015, 03:16 PM   #17
P1
P1's Avatar
11572
zx10guy,
Semper Fi
How does Swisstrax compare to Racedeck when it comes to price?
      01-21-2015, 05:49 PM   #18
MrPrena
MrPrena's Avatar
Drives: BMW Hyundai Nissan
I need to get this done asap!
The Magnesium Chloride is killing my garage floors!
I did some HW, and they are selling these at 0.89/sqft, and my garage is about 400-450sqft? I am over the budget to do Home Improvement from new flooring.
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
      01-21-2015, 11:36 PM   #19
E90SLAM
Supreme Allied Commander
E90SLAM's Avatar
Hong Kong
1963
Drives: A BBS WHORE
I did Epoxy 5 years ago and its holding up well, except the strip facing the sun outside the garage door. Which it faded yellow under california sunshine.
I just bought the kit from Home Depot and DIY. Washing and prepping/etching the floor took the most time.
      01-22-2015, 08:35 AM   #20
Former USMC
Good question - about $4.00 a square foot - any color, includes shipping. Not sure about the cost of Racedeck.
      01-22-2015, 01:10 PM   #21
P1
P1's Avatar
11572
OK, that's only slightly more expensive than Racedeck. Their FreeFlow tiles are $3 per square foot.
