BMW X3 Forum
BMW X3 Forum
      01-17-2015, 08:15 AM   #1
Scandic24
Scandic24's Avatar
Sweden
45
Drives: X4 30d MSport
xLine details retrofit
Anyone knows if it's an easy task to retrofit the front air intake xLine inserts?
Does the whole bumper have to come off or are the inserts snap-on?
      01-17-2015, 12:32 PM   #2
Bimar
Bimar's Avatar
800
Drives: Bmw X
Would need to check. You have the base X4 or a MSport?
      01-17-2015, 04:01 PM   #3
Scandic24
Scandic24's Avatar
Sweden
45
Base.
I've checked etk for the parts put can't figure out if this is a DIY job or...
      01-17-2015, 08:39 PM   #4
Bimar
Bimar's Avatar
800
Drives: Bmw X
Originally Posted by Scandic24 View Post
Base.
Should be DIY, have you checked Realoem.com for parts assembly?
      01-18-2015, 04:35 AM   #5
Scandic24
Scandic24's Avatar
Sweden
45
Yup, parts assembly here:
http://www.etk.cc/bmw/EN/search/sele...CE/51/51_9784/
It's not absolutely clear what goes where...
      01-19-2015, 02:29 PM   #6
TomaGo
TomaGo's Avatar
France
91
Drives: BMW X4
Hello,
In my opinion it is a DIY mod. I'll do it on my X4 after delivery in march.
Tom
      02-09-2015, 09:56 AM   #7
Scandic24
Scandic24's Avatar
Sweden
45
Ordered the parts assembly for the X-Line air intake trim.
I had to get new plastic "fake" air intakes as well as the trim details. The grille intakes seemed to need a bit more effort to put in place so I had my shop to do it. The trim details are snap-on so I'll be able to fix that later by myself (they came un-painted, and instead of buying a can of silver spray, I took them to a shop specialized in foiling).
      03-05-2015, 01:04 PM   #8
Scandic24
Scandic24's Avatar
Sweden
45
Here's the result. Foiled trim snapped in place.
      03-06-2015, 04:07 PM   #9
TomaGo
TomaGo's Avatar
France
91
Drives: BMW X4
Hello,
I havé received my trim for XLine retrofit today, so i have a few questions :
- so what did you do about the painting ?
- did you change the black grill behind the trims ?
Thanks
Toma
      03-07-2015, 04:32 AM   #10
Scandic24
Scandic24's Avatar
Sweden
45
Originally Posted by TomaGo View Post
Hello,
Thanks
Toma
- I had the trim foiled, not painted.
- Yes! They are completely different. They have the tabs and notches needed to be able to fasten/snap-on the trim.
      03-07-2015, 06:14 AM   #11
TomaGo
TomaGo's Avatar
France
91
Drives: BMW X4
Ok, thank you for your answer.
Do you plan to add also the center big trim from X Line ?
      03-07-2015, 07:00 AM   #12
Scandic24
Scandic24's Avatar
Sweden
45
No, not now.
xbimmers
