01-15-2015, 03:35 PM | #1 |
258
Rep 319
M Brakes vs Stop Tech Brakes
So I just had M Brakes installed on my 2014 328i. I was told that I should have gone with the Stop Tech big brakes because the M breaks have a soft pedal feel. Does anyone have any feed back on this?
Thanks
2024 X3 M40i. wife says no Mods since it's aLease.. I see a JB4 tune in the near future.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune, Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired |
01-15-2015, 04:28 PM | #3 |
2657
Rep 3,401
StopTech brakes are among the better braking systems you can buy. They have been used on dedicated track-cars for years.
M Performance brakes are the same brakes available on a 3 or 4-Series as a $650 option with the only difference being slots/dimples on the rotors and choice in color. |
01-31-2015, 10:30 PM | #4 |
16
Rep 234
M Brakes don't have the slotted and dimpled rotors. Those are on the M Performance BBK.
I had the 2wheel StopTech kit on my E46 but with the F30 I would go with M Perf BBK because of the coding which take advantage of the four wheel brake upgrade (ASC, DSC, ABD, etc). It would be a struggle to get the same coding done with the StopTech kit. And yes all these systems are tied into and affect the brake system. |
02-01-2015, 12:25 AM | #5 | |
1065
Rep 4,856
02-02-2015, 01:02 PM | #6 |
83
Rep 418
You can help eliminate the spongey feel with braided hoses such as those made by Goodridge or HEL. And if that's not good enough, then ditch the current pads for whatever is recomended in this part of the forum - perhaps some Porterfield R4S front and rear. Also benefit from reduced pad dust build up on rims being ceramic with these.
02-04-2015, 10:51 AM | #7 |
258
Rep 319
I've had the Brakes on for a few weeks now and Auto X event for January went great. the Breaks have absolutely no spongy feeling at all. They stopped on a dime every time. I think I will change out the hoses to Braded ones here in the next month before I do the HPDE event coming up.
02-25-2015, 11:58 AM | #8 |
7
Rep 34
http://www.turnermotorsport.com/t-br...fferences.aspx
This link a good breakdown of all the different brake system and options BMW has been so confusing about with their lack of clear options (more so '12-'13 years). There is another link for 335i/xi. But also according to Turner Motorsport you can just throw in the StopTech pads into your existing M or M Performance 4-piston brake calipers if you feel the M Performance pads lack feel or are spongey. |
02-25-2015, 12:02 PM | #9 | |
1604
Rep 3,940
02-25-2015, 12:12 PM | #10 |
208
Rep 1,161
I find that pedal feel is most determined by brake pad compound. Brake hose reinforcing technology has help reduce ballooning in rubber lines, so a set of stainless lines can help but have much less effect than they used to. Get yourself a high-performance pad with good low-temperature bite and you'll be all set.
02-25-2015, 12:41 PM | #11 | |
83
Rep 418
F: AP1609 R: AP1656 But please double check on realoem.com and cross reference via Porterfield's website. I did, for you, cross referenced myself and it checked out, but I don't know your car details. If your front pad part number is 34116859282, then I'm confident I'm correct. |
03-23-2015, 03:00 PM | #12 |
258
Rep 319
So I ran the 328i at COTA this past weekend. I have no complaints with the M Performance Brakes. No spongy feeling at all, even coming down from 130+ along the back stretch into turn 12. I would like some Ceramic pads for next time though.
sly1types431.50 |
03-23-2015, 08:22 PM | #13 | |
472
Rep 577
Who did you have do the install? Could you PM me what you paid. I live in Austin, but would take a trip to Houston for the result you got. |
02-11-2019, 06:14 PM | #14 | |
Masterchief
354
Rep 1,003
have you encountered any humming/buzzing noise from your front wheels?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
04-20-2019, 05:57 PM | #15 |
339
Rep 716
Drives: F90 M5
all i can say is that i have the ST Trophy BBK and it feels amazing lmao
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
04-29-2019, 10:26 AM | #16 |
Not stock
472
Rep 617
The spongy brake pedal feeling with M Perf brakes is coming from people who mechnically install the kit but do not code the car. I installed my own M Perf kit and drove the car post-install but pre-code, and the pedal definitely felt "off". Too much travel, smooshy. Coded the car and it firmed up to stock/original feeling. This was with stoptech stainless lines installed.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
