E93 40W Angel Eyes Fitted - Question about passenger side outter ring
01-13-2015, 03:20 PM | #1 |
160
Rep 2,399
So finally managed to get my hands in the compartment and fit some new bulbs that came yesterday
there both locked in fine. drivers side looks ok. both rings light up but obviously inner ring is way more lit passenger side however outter ring doesnt seem to be lit up like driver side outter ring? have i done something wrong? there both locked in right. Drivers Passengers Any ideas? |
01-13-2015, 04:29 PM | #2 |
25
Rep 405
Try taking the bulb out, turning it 180 degrees, then putting it back in. The LEDs may line up with the light tube better as there's pretty large gaps between each LED.
01-13-2015, 08:22 PM | #3 |
Nurburgring Nate
Rep 116
This is exactly what happened to me, but on my driver's side. The tube that the light goes into bends really easily, and when you screw the bulb in it's really easy to misalign the tube. If that's not it, make sure both LEDs on the bulb are actually working. It could just be a problem with the bulb.
"I'd rather lose by a mile because I built my own car than win by an inch because someone built it for me." -Moog
2008 335i Sport Package |
01-14-2015, 03:30 AM | #4 | ||
160
Rep 2,399
01-14-2015, 08:35 AM | #6 |
25
Rep 405
I don't think it was a poor design. The original bulb was an incandescent type and therefore had 360 degree light. The aftermarket LEDs have the LEDs on 'sides', which have a gap between them. If LEDs had the light all the way around, they would be brighter, as the tube would be guaranteed to pick up more light. It's a bit hit & miss when you fit LEDs into the holders. You never know if the LEDs will be directly facing the tube.
The original idea was to light the outer ring and give the halo effect and they do exactly that with an incandescent bulb. We are trying to almost replicate the LCI factory LED look and that's not going to happen. |
