F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Using a 12v Battery Charger on 14.4v battery
Extreme Powerhouse
      01-12-2015, 10:36 AM   #1
pdawgped
Drives: 328d
Hi,
I'm wondering if I can use my 12v battery charger that I bought for my other vehicle on my f30.
I know the bmw chargers charge at 14.4v but I'd like to avoid buying another charger.
Anyone see any harm? I'm assuming it'll just take longer to charge the battery.
This is the charger I have:
http://www.canadiantire.ca/en/pdp/au...-0111927p.html
Thoughts ?
Thanks
      01-12-2015, 10:47 AM   #2
cryptz
Drives: 2015 m4
isnt the bmw battery 12v also? Your alternator generally produces around 14.5 volts in modern cars but the battery itself is 12v. The 12v charger is generally a classification (12v vs 6v) i would still think it produces higher then 12v for actual charging.
Unless there is something really weird with what bmw is doing as far as batteries go (this is my first bmw and i havent touched anything electrical) i think you are just confusing the voltages, its most likely a 12v battery.
      01-12-2015, 11:58 AM   #3
pdawgped
Drives: 328d
Cryptz,
I think your right. Did some research, asked around and the Battery is 12v.
14.4v is the charging voltage required to charge the 12v battery.
That's where I got confused.
Any battery charger designed for a 12v battery will actually use more voltage to than 12v to achieve a full charge.
Thanks for the response!
      01-12-2015, 01:23 PM   #4
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
Remember to connect to the terminals under the hood and not directly to the battery. No quicker way to fry a computer than to spike it with a connection to the battery.
Appreciate 2
f30post
