01-11-2015, 09:57 AM | #3 |
27
Rep 518
definately nor sitting right mate. dont understand why it would be out of place unless somebody has fiddled with it before and the only reason i can think the boot would have been removed or replaced is if it was in an accident??
i know what you mean the roof is all connected to the boot. any good garage should be able to realign it. |
01-11-2015, 10:26 AM | #5 |
96
Rep 2,204
Accident damage mate - they don't just go out of alignment !
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
01-11-2015, 11:30 AM | #7 |
24
Rep 285
I'd suspect accident damage Is the light fitting correctly from the picture it does looks like the o/s needs going forward a little, could you put up some more pics??
01-11-2015, 11:39 AM | #9 |
24
Rep 285
having seen the 1st pic I'd say its the lamp area that's taken a hit, what's the gap like on the top front of the boot lid? need to see all gaps on the lid both sides bottom bumper and top
01-11-2015, 12:35 PM | #10 |
160
Rep 2,399
01-11-2015, 01:30 PM | #13 |
26
Rep 315
Have you tried loosening the light cluster & repositioning them, could just be out slightly. Looks like the top right of the cluster is sticking out and the inside is too far in
2010 E92 Msport lci
01-11-2015, 01:31 PM | #14 |
160
Rep 2,399
01-11-2015, 02:14 PM | #16 | ||
130
Rep 1,534
01-11-2015, 03:17 PM | #17 |
68
Rep 937
The boot is fine, it's clearly the outer light units sitting too far in if you look at the bottom of the outer light cluster.
The boot lid is flush with the panel running under the lights.. Get those lights off & adjust the fittings.. |
01-11-2015, 03:41 PM | #18 |
24
Rep 285
I have an e93 myself and the inner wings inside the boot have a reinforced channel running round the inner wing of the quarter panel on each rear wing, speaking from experience it looks like the o/s side lamp area has taken damage and maybe deformed the channel a little resulting in the lamp not fitting correctly, you could try adjusting the lamp alternatley have look at the other side taking measurements and compare for any differences.
01-11-2015, 03:48 PM | #19 |
448
Rep 3,312
That's definitely the outer light cluster that is off. Where the light cluster meets the inner light on the bootlid you can see it's pushed in. The bootlid looks fine tbh.
First job is remove the outer cluster and check the gasket is there and the fitment.
E92 335i / M3 Hybrid - The Build
01-12-2015, 04:19 PM | #21 |
448
Rep 3,312
The gaps now there because you've pushed the cluster out using washers etc. tbh the problem with that is there is probably a gap behind the cluster now and water will ingress there.
