2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Questions about muffler delete, aftermarket exhaust, exhaust flap, codes…etc.
      12-30-2014, 11:33 AM   #1
Roman G
98
Drives: a few
Hi fellow 2ers
I’m thinking of doing muffler delete, but I want to hear it first before committing to it.
The Plan:
Take the muffler off and see how it sounds and to see if I like it. There is a video or two of muffler delete but I need to hear it in person.
The Problem:
Removing the exhaust means no more muffler flap and Im worried it will throw a code. I have searched and found some people got caught by the dealer when doing the golf tee mod.
My main concern is that there will be no codes thrown.
Those who went muffler delete route or aftermarket exhaust, how did you deal with exhaust flap and what did you do?
How about m235 muffler? I believe it will fit, which has a flap, therefore, no codes?
If still no good, I might have to purchase and gut the OEM muffler with the flap intact.
The wait for the 228 m performance exhaust is too long and who knows if it will happen.
Thanks for any suggestions.
Roman
      01-11-2015, 08:32 PM   #2
i8ur911
125
Drives: F22 228i MSport
I can say that the M235i system will bolt up without any problem other than the rear valance....which is an easy fix as you can buy the M235i one for fairly short money.
In regards to removing the exhaust flap and getting a "code", it won't happen. The exhaust flap works on vacuum. It's easy enough to remove the system and plug the vacuum line......no codes.
      01-12-2015, 03:23 PM   #3
Roman G
98
Drives: a few
Thank You, I am leaning more and more towards 235 exhaust. I just wish there was a video of one. The only thing you can find is 228s with muffler deletes.
      01-13-2015, 07:21 PM   #4
i8ur911
125
I would think that the sound would be similar to the M235. I don't think it would be a huge difference from engine to another.....likely different, but not WAY different.
      02-04-2015, 12:36 PM   #5
e46m3lol
e46m3lol's Avatar
Drives: F30 FBO, E70 X5D, W204 C63 FBO
I am speaking from experience as I have done the muffler delete along with a million other mods. When unplugging the exhaust valve the check engine light won't come on the dash but if you run the codes with a BMW code scanner then you will get a code for "exhaust flap malfunction" nothing to worry about but just thought I'd let you guys know.
      02-04-2015, 01:36 PM   #6
Icy J
im a car
Icy J's Avatar
Hong Kong
734
Drives: 220i M Sport | 520i M Sport
2014 BMW 220i  [10.00]
They sound VERY different, lol
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB]
Instagram: @icyj95 | FB
      02-04-2015, 02:55 PM   #7
Ian_Mark
United Kingdom
14
Drives: '14 228i MSport
2014 BMW 228i  [0.00]
2005 Subaru Sti  [0.00]
I'm about to do the same tomorrow. Got a m235i exhaust switching it with my stock
      02-04-2015, 08:47 PM   #8
i8ur911
125
Have you listened to the M235i MPE on a 228i and then listened to it on a M235i? I wouldn't call that VERY different.....lol.
      02-05-2015, 09:21 AM   #9
Icy J
im a car
Icy J's Avatar
Hong Kong
734
The volume may be similar but the tone and exhaust note themselves are very, very different. The only similarities I can think of are the cold start and the 'crack' you get when upshifting, as well as the burbles when releasing the gas.
The 'better' sound is of course subjective, but a rear muffler is not going to change the sound that the engine itself produces. Installing an exhaust meant for the N55 is not going to make the N20 sound like an N55, no matter how much I wish that were the case. I've heard a F30 335 and 328 accelerate past me one after another, both with modified exhausts, and I can assure you that they sound nothing alike. The M235 MPE sounds fine on a 228, but it doesn't sound like a M235. I have a M135 stock exhaust on my 220 and that doesn't make it sound like a M135/235
      02-05-2015, 03:49 PM   #10
Ace604
11
Drives: 2019 M2C
Exactly. If you put a Ferrari 458 exhaust on a n20 its not gonna make it sound like a Ferrari. Engine configuration and layout determines the exhaust sound. Exhausts can only enhance or muffle the sounds already produced by the engine.
      02-16-2015, 06:02 AM   #11
huma
huma's Avatar
93
Drives: U11 one day
The stock M235 muffler bolts onto the 228?
      02-16-2015, 07:00 AM   #12
Icy J
im a car
Icy J's Avatar
Hong Kong
734
I use a stock M135 muffler on my 220 - needed slight modification, mainly to the exhaust tips (as well as the midpipe being a different diameter), so I assume a M235 exhaust would need even less modifying
      02-20-2015, 11:17 AM   #13
e46m3lol
e46m3lol's Avatar
Yes a stock 235i exhaust bolts up perfectly to a 228i as long as you get the 235i rear diffuser to accommodate the dual tips.
      02-20-2015, 11:42 AM   #14
Roman G
98
Drives: a few
Thanks for the comments guys.
It doesn't look like we are ever going to get the m performance exhaust for the 228, I might as well go with the 235 muffler.
      02-20-2015, 04:18 PM   #15
Bam226
105
Drives: BMW 228i M sport
Wouldn't the 328 m exhaust work?
      02-25-2015, 01:43 PM   #16
Thescout13
Thescout13's Avatar
Drives: '20 F80 M3CS, %E2%80%9818 GT3
Yes it would. Fits like a glove. Only thing you need to do is extend the hangers about a half inch
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE
Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene)
Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017)
Search this Thread:
Advanced Search
2addicts
