2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Spacers?
      12-25-2014, 08:23 PM   #1
FeckinSpaceman
FeckinSpaceman's Avatar
270
Drives: 22' M240i
2022 BMW M240i  [0.00]
Spacers?
Hey
I am lowering the 550i on H&R springs and I am wondering if I should run spacers? At least in the front?
If so what size would you recommend?
Here are my wheel sizes and offsets.
Front
20x9 et35
245/30/20
Rear
20x10 et35
285 /30/ 20
2022 M240i Thundernight Metallic / Oyster
Previous
2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i
      12-26-2014, 12:18 AM   #2
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
Yes, you can have spacers all around if you want. My summer setup is Vorsteiner VS-310 20X8.5 ET20 and 20X10 ET28 with 245-285 Michelin PSS tires and it sits very flush (pics before lowering):
This setup is equal to 20X9 ET26 and 20X10 ET28, therefore it is clear that you can run 8 mm front (with 245) and 8 or 10 mm rear (with 275).
I would also recommend you to make the very simple measurements on your wheels: http://www.turnermotorsport.com/t-te...l-spacers.aspx. In fact, the F10 fenders and axis are standard, but the different aftermarket wheels and tires of the same specs can introduce minor shape deviations depending on their design and size.
      12-26-2014, 08:13 AM   #3
FeckinSpaceman
270
Drives: 22' M240i
My bad, my rear tires are 285, I updated my first post
Thanks for the info. Sounds like 8 mm for the front might look nice.
After i get the springs on I will measure to be safe.
Previous
      12-26-2014, 08:27 AM   #4
valbmw
valbmw's Avatar
94
OK so have 5 mm for the rears, and it will be fine ) Please don't forget to get the lug bolts extended to the same added length: there is not that much of bolt thread effectively used. The extended bolts normally offered together with the spacers. And: measurements never hurt!
      01-01-2015, 02:03 PM   #5
FeckinSpaceman
270
Drives: 22' M240i
Btw, thank you... I see you all over the boards recently and you are a wealth of information
Previous
      01-04-2015, 03:55 PM   #6
843f10
12
Drives: alpine white f10 535i
i have 15mm in front and 20mm in back with h&r and i love the set up
      01-04-2015, 06:16 PM   #7
zugellos
Drives: 535i M-Sport
I too, am running 15mm up front and 20mm in the rear on my OEM 19's; H&Rs too (the Sport Springs version).
Very aggressive, but I love'em that way.
      01-04-2015, 07:18 PM   #8
FeckinSpaceman
270
Drives: 22' M240i
What wheel width and offsets you guy s running! Looks good
Previous
      01-04-2015, 09:14 PM   #9
843f10
12
just the stock wheels...not to sure of the offsets. thanks!
      01-04-2015, 10:26 PM   #10
zugellos
My OEMS 19's are:
19x8.5 ET33 (w/15mm spacers ET=18)
19x9.0 ET44 (w/20mm spacers ET=24)
      01-21-2015, 09:06 AM   #11
DenisZ
Drives: 535xi
Wait... i can use spacers on 535 x drive?? :0
      01-21-2015, 06:10 PM   #12
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
On OEM wheels you mean? Yes.
      01-21-2015, 07:12 PM   #13
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Absolutely. The X Drive system can't tell the difference. It can only detect diameter differences.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      01-22-2015, 01:19 PM   #14
astroboi
Drives: 2011 528i
Question. Are spacers irrelevant from the shock and struts? By saying that I can get any brands of spacers as long as they fit with the requirement of F10?
Thanks!
'11 528i Space Grau Metallic
Plasti-dipped Emblem
Premium Package 2
Adaptive light control
Xenon headlights
      01-22-2015, 02:04 PM   #15
valbmw
valbmw's Avatar
94
Thanks!
Absolutely. Spacer is nothing but an artificial extension of a wheel hub made to move the wheel outwards. Using spacer is even good because gives the wheel a bit more space by moving away from the suspension elements (shocks and struts). But not to make the spacer too thick because the tire will start rubbing the fender.
      01-22-2015, 02:09 PM   #16
astroboi
Drives: 2011 528i
Got it Valbm. That's a good information. And finally, will I have the option to install lowering springs in the future, if I just get a moderate length spacer, say 15mm?
Premium Package 2
Xenon headlights
      01-22-2015, 02:41 PM   #17
valbmw
valbmw's Avatar
94
Yes you will. Like most of the members here who have already done lowering + larger wheels + spacers for flush and aesthetic look.
The thing is, the spacers should come the last, and measured together with the wheels. Depending on a specific tire brand and square/stretched tire shoulder shape, you can afford different offsets/spacers.
As for the spacer technology, the lightest ones are the best, for example RS Technik. Also they must have the extended lug bolts (normally sold together).
      01-22-2015, 06:53 PM   #18
DenisZ
Drives: 535xi
Thank you!!
5post
