12-24-2014, 05:16 PM | #1 |
Enthusiast/Former CA
17
Rep 55
How in the hell do you replace the front side markers?!?
I already read the ind install guide but can't seem to take the markers out in the first place. They are tight! Anyone have any advice for a man with average Grip strength? I asked my bro with bigger hands and even he couldn't get it out.
12-24-2014, 05:36 PM | #3 |
8
Rep 140
There are a few bolts inside the fender which can be unscrewed and your hand can fit in between the plastic liner and the bumper. I don't recall the exact details but there is definitely a DYI on the forum. It's pretty simple.
Good luck. |
01-06-2015, 06:40 PM | #5 |
10
Rep 62
I used needle nose pliers to squeeze the top clip and then used them to push and just force the bottom clip out if your still having trouble. Broke the clip on the reflector though...
01-06-2015, 06:44 PM | #6 |
1399
Rep 5,262
http://www.2addicts.com/forums/showt...ange+reflector
just remove 3 or 4 of the screws so you can fit your hand and then push and squeeze the top clip out... then just pull from the reflector and the bottom will come off |
01-22-2015, 08:52 PM | #7 |
14
Rep 56
If you crank the wheel all the way to the inside it will be easier to do your business in there. I still had a hard time with the inside clips and broke at least one clip on reflector. No damage to the car though.
01-22-2015, 10:43 PM | #8 |
150
Rep 395
My index finger still hurts a bit from doing mine earlier this week. You have to put a TON of pressure inwards on those clips to get them out. I actually ended up forcing one out a bit as I lost my patience and it bent the clips a bit. I didn't care since I won't ever be using them again.
Then I moved on to the door handle key lock cylinder delete. Tried that for hours and eventually gave up and sent the item back to iND. |
