Need help with Brake light refusing to reset! brakes at ---- km/mi
12-21-2014, 08:15 PM | #1 |
16
Rep 128
I went to reset my brake mileage in the computer because it said i had 700 miles left on my rear pads. it was giving me a yellow car on a lift on startup. i did the procedure where you have the door closed, put the key in hold the mileage button and it comes up to reset. but once i did this, it threw a red brake light on the dash that is constant, the yellow lift changed to a red lift and now, it tells me "brakes at ----" after hitting the reset button. i tried disconnecting the sensor and reconnecting it in both front and rear and got nothing. any help would be appreciated.
12-22-2014, 07:14 AM | #3 | |
16
Rep 128
12-22-2014, 12:37 PM | #4 |
41
Rep 692
12-22-2014, 12:57 PM | #5 |
16
Rep 128
Yea but it's coming up both front and rear when originally it was just giving me a warning for rear now it won't let me reset either and they both have the ----- next to them, I read to try to jump the connector and then reset it, that sound like it would work?
12-22-2014, 12:58 PM | #6 | |
41
Rep 692
12-23-2014, 08:56 PM | #7 |
16
Rep 128
ok so i went out and bought a brand new rear sensor from bmw, take off my rear wheel, remove brakes which were at 50% if not more, replace new sensor and I'm still getting a code for rear brake wear sensor and it is still giving me ----- when i go to reset it.....someone please help me out here.
12-24-2014, 03:56 AM | #8 |
1254
Rep 4,088
Replace both sensors at same time with new sensors and then try to reset. The reset won't hold for rear if front is also tripped and vice versa.
12-24-2014, 07:15 AM | #10 |
2341
Rep 3,539
12-24-2014, 10:29 AM | #11 |
16
Rep 128
Yea I'm going to try that now, and the front one isn't tripped, when I check with bav tech tool I get a code for rear wear sensor, doesn't make any sense
12-24-2014, 11:17 AM | #12 |
16
Rep 128
ok so battery disconnect did nothing, still getting ---- when i turn the car on and try to reset the sensors. like i said i replaced the red sensor so it should have let me reset it once i did that, but it won't let me reset front or rear....im not going out and spending another 25 bucks on a sensor for front pads when they are almost brand new and going through all the hassle of replacing that sensor just to find out it won't fix my problem. I'm lost on this whole issue and about to just bring it in to the dealer. my fear is their going to tell me its the DSC unit which i know is BS because if i damaged the unit just by prematurely resetting the brake service light these cars are shit.
12-24-2014, 01:18 PM | #13 |
28
Rep 367
sometimes you have to replace both the rear and front sensor first, then reset the brakes through the car. I had same situation as you, I just had to replace my rear sensor but sometimes you need both.
12-24-2014, 03:12 PM | #15 |
2341
Rep 3,539
Did you inspect if you have any of the pins broken off in the female housing on the car?
Maybe one broke off and it causing problems |
12-24-2014, 10:06 PM | #16 |
16
Rep 128
Thanks everyone for the advice and help, I ended go speaking with a tech over at BMW Whos a good friend of mine, told me right away, U need to do them together, has something to do with the 3 wire system they run on, but again thanks everyone for the input and Merry Christmas everyone😃
01-01-2015, 10:39 AM | #17 | |
28
Rep 457
01-01-2015, 10:40 AM | #18 | ||
16
Rep 128
01-05-2015, 07:29 AM | #19 | |
681
Rep 3,696
01-05-2015, 08:33 AM | #20 |
1254
Rep 4,088
I think he means (and I agree) that if one sensor is showing as worn, the CBS logic won't let you reset the other even if it's new. You should physically replace both sensors, and then consecutively reset them via CBS stalk one after the other.
01-05-2015, 10:27 AM | #21 | |
32
Rep 269
I recently replaced my rear brakes and after changing only rear pads and sensor, I reset both front and rear via CBS stalk and everything worked out just fine.. |
01-05-2015, 11:03 AM | #22 |
1254
Rep 4,088
You're right, it shouldn't if the other sensor hasn't been tripped to the first stage (not open, but higher resistance). But I think the CBS logic is looking for a slightly difference resistance value, or perhaps a disconnect-reconnect sequence before it allows a reset.
All I can say for sure is, I have found the CBS logic to be ultra sensitive (probably too much so) and the only guaranteed method when nothing else has worked is to replace both sensors. I've run shorted sensor wires in the past with no issues, so I agree in principle with what you are saying. |
