12-19-2014, 05:24 PM | #1 |
1756
Rep 7,651
IND | DIY | European Spec Taillights
European Spec Taillight Installation
With their hint of amber, the European spec BMW taillights offer a unique look to U.S. spec vehicles. Tools required:
Step 1: Pop the trunk and remove the plastic screw from the black cover between the taillight and trunk liner. (flat-head screwdriver) Step 2: With the screw removed from the plastic panel, remove this panel. This will show you the two 10mm nuts securing the taillights to the vehicle. Step 3: Remove the bolts with the 10mm socket Step 4: Now that the bolts are removed, the only thing securing the taillights to the vehicle is a round plastic tab. To remove this tab, carefully mask the outermost corner of the taillight. Protect both the paint and taillight. Take the nylon pry bar and lift the taillight using leverage. Step 5: Carefully pull the tailight away from the vehicle and remove the PnP connector on the back of the housing. Step 6: Plug connector into the Euro-spec tailight and reverse the installation procedure.
12-20-2014, 07:27 AM | #2 |
10340
Rep 40,310
Drives: 2018 Alpina B6 650ix GC
Much better! I'm biased though as I put Europe Amber Turn Signals on my F10.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-20-2014, 06:57 PM | #3 |
421
Rep 4,499
NICE! I'm doing this, excellent work iND keep it up especially on the inexpensive mod!
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
02-13-2015, 11:09 PM | #5 |
932
Rep 4,323
Drives: M340
It is better to wait for the LCI tails and upgrade. No need to spend all the $$$ and do this twice.
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
02-14-2015, 04:00 PM | #7 |
782
Rep 3,145
Very Nice
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
