12-17-2014, 04:37 PM | #1 | |
BimmerPost Supporting Vendor
443
Rep 2,036
KW Suspension Solutions F80 M3 / F82 M4 | H.A.S. , KW V3, KW Clubsport | Winter Promo
Hello Members,
With Winter time here we are rolling out our Winter pricing on all KW solutions for the F8X M pltatform. Not only will we offer the best pricing but we will also bring our unparalleled level of service to the community. Feel free to PM me for more info or any additional questions. Quote:
KW V3 State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed. Compression- and rebound adjustment As far it is vehicle-specifically possible, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and also influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be adapted to the requirements of the driver. Moreover the driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics. The compression phase adjustment is carried out at the lower end of the shock absorber via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved. Damping technology with individually adjustable rebound- and compression technology inox-line* stainless steel technology Individually height adjustable Adjustment parameters approved by the German Technical Control Board (TÜV) High-quality components for long durability Infinitely variable rebound damping adjustment 14-way adjustable compression damping Unique, individually working damping force adjustment Comprehensive documentation for easy use KW Clubsport KW Clubsport coilovers was developed for customers, who demand a better handling car when participating in track day events, but also require a setup that could be used every day. The Clubsport was specifically designed for the Nordschleife using track day tires. By using the optional adjustable top mounts, the suspension geometry can be adjusted to the requirements of tires and the intended use. The mentioned adjustment options combined with the independently adjustable rebound and compression damping technology allow a suspension setup according to the vehicle load, tire characteristics and different track conditions. KW Clubsport meets every demand regarding a coilover for the usage on the road and the race track. KW Clubsport suspension kits are independently adjustable in compression and rebound forces and include high performance racing springs. Racing top mounts are optionally available for further performance. KW Clubsport guarantees excellent handling, best performance, highest agility and fantastic lap times. Height adjustable coilovers Performance setup for the racetrack Dampers in compression & rebound forces independently adjustable Use of high performance linear race springs/li> In stainless steel technology inox-line Additional available with racing top mounts KW Sleeve Kit Can cause issues when trying to lower vehicle all the way (~1.5) The perfect solution for the individual looking to lower their vehicle to the height they desire without going to a full blown coilover setup. Kit Includes: 4 Lowering Springs F/R Spring Perch Adjustment Tools Height Adjustable Spring Perches Strengthened bump Stops KW Shock Sleeves Last edited by Omar@VelosDesignwerks; 12-17-2014 at 04:52 PM.. |
