Exide OEM Spec Battery Installed & Registered
12-15-2014, 11:19 AM | #1 |
75
Rep 407
OEM spec Exide Group 49 Battery for sale with Installation and Registration. This is the same battery the only difference is that it isn't in a white shell, nor has BMW stamped on it. If you look at your OEM battery, it says Exide on top.
$200 Located in Queens & Nassau, NY
e90 jet black on terra//pure stage 2//fuel-it stage 3 lpfp & pi w. return//motiv tuned//vrsf dps//vtt inlets & outlets//helix fmic // er w. hks bov // bms dcis // spec stage 3+ w. mfactory smfw // cdv delete // clutch stopper // kw v1 // m3 control arms // whiteline fsb // cic|combox|backup camera retrofit // m3 headliner retrofit
12-20-2014, 03:16 AM | #2 | |
681
Rep 3,696
01-07-2015, 04:29 PM | #3 |
75
Rep 407
bumppppity
01-08-2015, 03:47 PM | #5 |
75
Rep 407
01-12-2015, 07:55 AM | #7 |
NYC ALIVE
32
Rep 646
shwinturbo where did you get your window trip wrapped at?
djkevinnn i'm going to text you later on today.
NYC ALIVE - Founder
Facebook - NYC ALIVE E90 335xi |Blackline Taillights | 35% Tints | Matte Black Grille | M-Tech Rear | M3 Rep Front | VRSF DP's | Borla Cat-Back Exhaust | JB4 G5 | KW V3's | |
01-13-2015, 10:03 AM | #8 |
75
Rep 407
Sounds good bro
01-13-2015, 11:18 AM | #9 |
Nomore
149
Rep 793
For anyone curious:
Im using the same battery. Researched here first. Nothing wrong with using this. Same as OEM. You can get them at walmart for $150 new with whatever 2-3 year warranty they offer free. Any new battery must be "registered" in the ecu. So coding should be done. Any new battery that isnt a somewhat close match to stock Amperage rating should have their ecu coded for the correct charge rate. I do not know OP. Just putting put some info to clarify. OP is providing mew battery installed with necessary coding/registering necessary, i assume.. |
01-13-2015, 04:41 PM | #10 | |
75
Rep 407
03-13-2015, 10:22 AM | #11 |
1081
Rep 1,761
Drives: S2000, MacanS, M4CS
Op, PM'd.
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold Instagram: Tommys911 |
03-17-2015, 03:28 PM | #12 | ||
15
Rep 365
