BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > M3 Steering Wheel on a 335i?
      12-09-2014, 03:44 AM   #1
Raymonndo
Raymonndo's Avatar
23
Drives: M2
Is it possible? And get the - on the left and + on the right flappy paddles working!?
Thanks!
      12-09-2014, 06:04 AM   #2
kong24680
Drives: Silverstone Metallic F06 M6 Gr
Thanks!
Yeah, it's all plug and play. You would also need the m3 paddles if your pre-lci.
      12-09-2014, 06:12 AM   #3
themanthatcan
17
Drives: 2008 E92 335i MSport
Yup it's easy enough buddy, I've done it on mine. The only thing to be aware of is you can't use the M3-specific multifunction buttons as they will stop the paddles from working, so you'll need to swap the right-hand buttons over from your old wheel
335i gone - no longer a BMW owner
      12-09-2014, 06:33 AM   #4
Raymonndo
Raymonndo's Avatar
23
Drives: M2
Hmm in which case could I get away with just buying the paddles?
      12-09-2014, 07:18 AM   #5
Greg330
Greg330's Avatar
67
Drives: E91 335i
On another note, Raymonndo do you have a build thread for your car?
I'm liking what i see in your picture but don't think i've seen any decent pictures of it??!
      12-09-2014, 07:28 AM   #6
Drshan0
Red 5
United Kingdom
Drives: BMW E46 330ci
Squintstream has done the paddles only on his 335i.....
      12-09-2014, 07:43 AM   #7
Raymonndo
Raymonndo's Avatar
23
Drives: M2
I'll get one going Greg .
Interesting! Be a much cheaper option just buying the paddles?
      12-09-2014, 09:07 AM   #8
RajB
RajB's Avatar
448
Drives: E92 335i
It is plug and play apart from the right side buttons as has been mentioned.
My sport wheel currently has dct paddles so sided. I'll be fitting my M3 wheel shortly too and be selling my sport one with dct paddles.
      12-10-2014, 02:44 PM   #9
old grey steve
old grey steve's Avatar
United Kingdom
283
Drives: MK 7.5 Golf R
makes such a difference with extended ali paddles the wheel makes such a difference, I still cant understand the push pull logic of the standard setup, in terms of fitting it was as stated a straightforward affair to sort out and done in no time at all really
      12-10-2014, 04:09 PM   #10
themanthatcan
17
Love the extended paddles Steve
As for the standard push-pull paddles, I actually prefer the way they work as it means you are able to change up and down gears with either hand. If I'm cornering and wish too change gear that setup makes it so much easier.
      12-10-2014, 05:08 PM   #11
Ao1
Ao1's Avatar
United Kingdom
123
Drives: E92 M3
The M3 steering wheel has a really nice feel to it. Its well worth upgrading, but beware, make sure you buy a steering wheel with the paddles. I didn't and it turned out to be an expensive mistake as the paddles can vary.
http://www.e90post.com/forums/showpo...65&postcount=8
      12-15-2014, 08:13 AM   #12
Edinnit
Edinnit's Avatar
7
Drives: 335i Hunting
Im with you. Being able to change gear up and down with 1 hand on the wheel is winner winner chicken dinner.
Instagram: Edinnit
