12-07-2014, 05:14 PM | #1 |
329
Rep 984
DIY: RW Carbon F8X Carbon Steering Wheel Trim
Here's a little DIY I put together for the carbon steering wheel trim as it doesn't look like anyone else has posted one and it's a bit of a pain in the butt.
1. Disconnect negative battery terminal using a 10mm socket/rachet. DON'T CLOSE THE TRUNK! 2. Grab a T20 Screwdriver (or if you don't have one something similar) and push straight through the hole on the left side of the steering wheel and push in the retaining spring (it will provide resistance) while also pulling up on the left side of the airbag. It might take a few seconds but you'll be able to pop the airbag out on the left side (compared to E46, 100x easier). Repeat for right side. 3. Now you will see the airbag connector at the back. Using a flat-head, push the connector down until you can pop it out. Put the airbag carefully aside. 4. Using your T20 Screwdriver/bit, remove the two bolts holding the steering wheel trim piece in. 5. Using your T20 Screwdriver/bit, remove the single bolt at the back, lower portion of the steering wheel holding on the steering wheel trim. Carefully remove the steering wheel trim (pull up and out). 6. Ok, now for the 'fun' part. Place your steering wheel trim upside down on a flat, protected surface and prepare to remove the six little (evil) metal retainers. I found it easiest to use a razor blade to get them started by wiggling it back and forth. Then follow with a small eyeglass flat-head screwdriver and a pocket flat-head to get them all the way off. Do this for all of them until the trim is loose, and then remove the inner trim from the outer (pull up and out). 7. Now that you got those dang metal retainers off, put your new fancy carbon trim insert into the outer trim portion. Time to put those metal retainers back in! First, use a small hammer to flatten the bottom edge down again. Now, you will have to use some pressure with your fingers to get them started back onto the trim prongs. Next, use a 5mm 1/4 socket to put over the metal retainers, and again use your little hammer to hit them down until they are all the way on. Congrats, the new carbon trim is on and secure! Installation is the reverse of removal. Don't forget to clip the airbag connector back in! And to put the airbag back on just use your hands and put pressure evenly on the airbag until it pops back in. Congratulations, your interior just became even more expensive!
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
02-08-2015, 06:19 PM | #4 |
329
Rep 984
Not that I am aware of unfortunately, though it would be nice!
02-08-2015, 09:30 PM | #5 |
bigdaddyjulio
12
Rep 185
Nice write up... I just installed carbon steering wheel on my buddy's dinmann M3.
Nice to see both options
Big Daddy Julio
02-18-2015, 10:21 AM | #8 |
_______
169
Rep 1,088
Evil is an understatement. Thanks for the DIY. I just went in and manhandled those clips until they popped. Used a regular flat tip to get leverage.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
04-04-2015, 01:29 AM | #9 |
340
Rep 2,232
Drives: Made in Bavaria
Great...thanks
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten '15 BMW M3 (Black/Black) - gone not forgotten '10 BMW X5M (Black/Black) - gone not forgotten '08 BMW M3 (Space Gray/Black) - gone not forgotten |
04-09-2015, 07:39 PM | #11 |
75
Rep 991
Drives: 2015 BMW M4
you kiss your mother with that mouth?!
2015 ///M4 F82 [ Mineral Grey | SO Ext | 19" Black | 6MT | CFRP Interior | LED | Executive | Side/Top Cameras | Adaptive M Suspension | HK Surround ] :: will code locally for rum, beer, or chicken; PM as desired :: Instagram: IMrMark |
04-22-2015, 11:38 PM | #12 |
72
Rep 230
woooohoooo just installed it!!! Thanks for the diy. Once you finally get the first clip off the rest are definitely easier. You really have to pry those suckers off.
04-22-2015, 11:52 PM | #13 |
340
Rep 2,232
Did you re=use them at all? Anyone buy new ones from the factory?
04-23-2015, 04:07 AM | #14 |
_______
169
Rep 1,088
Reused all of them. No issue getting them back on. Hard part was getting then off.
07-07-2015, 05:36 AM | #16 |
Philly50
Rep 3
Drives: F82 MY16 BMW M4 Alpine White
11-24-2017, 03:58 PM | #20 | |
265
Rep 443
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM |
02-10-2020, 02:29 AM | #21 |
15
Rep 172
I seem to have broke the Retaining clips. Does anyone know where I can find replacement ones ? Dealer needs a part number, and have no idea how to obtain one. Thanks
05-23-2020, 06:09 PM | #22 | |
66
Rep 154
