Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      12-05-2014, 03:50 PM   #1
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Blind Spot Warning
I find the blind spot detection in my M4 to kinda suck compared to other cars on the road and I'm curious to see if anyone knows how to make some adjustments via coding.
Whenever i am driving on the highway i look at other brand car mirrors to see how their systems work and have noticed that on Mercedes & Lexus the light is on anytime a car is in the blind spot. On my M4 & the other half's X4 the light is only on if the car just "sits" in the blind spot. If the car is passing you even at a very slow speed the light doesnt even come on at all plus it doesnt come on at low speeds. I think the system should alert me anytime a car is there regardless of speed and rate of passing.
Does anyone know if some of these settings can be adjusted on F8x? I know on the F10 there are some things that can be done but i cant find them on the F8x.
EDIT: here is the setting to turn it on at 17MPH vs. 30 MPH
ICM 3000 C_ZSW_Aktivierunggeschwindigkeit_Funktion_low Set to 30km Blind spot monitoring on at 17mph
      05-25-2017, 11:24 AM   #2
nycaudioma2
13
Drives: '18 M4
Just thought I'd revive this thread as I have noticed the same exact issue. Does anyone have any suggestions or coding improvements? The blind spot system is almost worthless to me with the way it currently functions from the factory.
      05-25-2017, 05:09 PM   #3
tastes jigga
tastes jigga's Avatar
Drives: '19 750i xDrive
I've been very impressed with the blind spot monitoring. It seems to pick cars up from a far distance back if they're traveling at a much higher rate of speed than me. I believe the sensors are pointed backwards (versus sideways from the rear corner). I've noticed it struggles when cars are directly next to me, but I'd rather have it this way.
gspannu199.50
      05-25-2017, 05:11 PM   #4
AIRHEIR
X3M Comp
444
Drives: X3M Comp
It's useless. Driven a Mazda 6 that has better than this one. It is so hit or miss it's not even worth relying on it.
      05-26-2017, 04:51 AM   #5
gspannu
United Kingdom
200
Drives: F10 535, F82 M4
I too am quite happy with the way these work. Nothing beats a over the shoulder check and should always remain the preferred option anyway...
      05-26-2017, 11:32 AM   #6
backagain
just a fool
backagain's Avatar
China
345
Drives: 2016 SO coded M3
I checked this on my morning commute. The sensors never failed once for any car in the blind spot (not parallel), whether the other car is moving at the same or a different speed. Also my experience with the steering wheel vibration confirms it is very reliable (even though I always visually confirm the clearance before changing lanes).
On a related note, I've coded the detection speed down from 50kmh to 20kmh.
gspannu199.50
      05-26-2017, 01:02 PM   #7
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
Agree that the system kind of sucks on the M3/4. I also find it difficult sometimes to even tell if the light is on, especially on a bright day. Seems like the other brands like Lexus/Mercedes which have the indicator in the mirror itself instead of as part of the housing are easier to read.
      05-29-2017, 08:30 PM   #8
M4Now!
292
Drives: MG / SO F83
Mine work great. However, I have noticed that they seem more sensitive to cars coming up behind you, vs. when you pass a car (which makes sense). Also, think they switch off below a certain speed?
Cheers
Bye bye E93 M3 - Hello F83 M4!
      05-30-2017, 01:42 PM   #9
gspannu
United Kingdom
200
Cheers
You can code the speed to activate at lower speeds as per #1 above.
      05-30-2017, 06:49 PM   #10
RickFLM4
RickFLM4's Avatar
Drives: M4
I noticed the same thing when I got my M4 - the light isn't nearly as visible as it was on my Audi S4. I really liked it on the Audi and don't think it has much value on the M4. It's not in a great place, isn't that big and isn't bright enough to be easily visible with a glance.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
f80post
