12-01-2014, 02:51 AM | #1 |
25
Rep 120
Drives: 2018 BMW M240i
MPE with and without diffuser
I was checking the parts catalog, and I noticed that there are two options for the MPE (source): one for use with the diffuser and one without. They have different part numbers, and different prices. The one with the diffuser is $1,100, and without the diffuser its $1,233.03 (source). But in the diagram they're identical.
What's the actual difference between these two options? |
12-01-2014, 03:49 AM | #2 |
170
Rep 1,215
When you want to use the exhaust with the m performance diffuser, you need a much longer version.
If you get the option with diffuser und use the stock diffuser, the tips will stick out way too much.
MANHART MH2 400 Partout FS: MANHART MHtronik Tuning Box http://www.2addicts.com/forums/showt...5#post18819345 |
12-02-2014, 12:30 AM | #3 |
25
Rep 120
Hmm, interesting. Are there any pics of the systems that show the difference in length?
12-02-2014, 06:48 AM | #4 |
170
Rep 1,215
before:
after:
12-02-2014, 01:23 PM | #5 |
25
Rep 120
Great, thanks for the pics!
02-27-2017, 12:55 PM | #8 |
5552
Rep 5,369
Keep in mind those aren't the OEM M-Performance tips. Those are aftermarket pieces. The OEM M-Performance tips won't stick out quite as far as depicted plus the M-Performance tips are not slash cut. I have the "long" M-Performance muffler on my M235 without the diffuser. It looks fine, but with the diffuser would look better.
03-06-2017, 11:57 AM | #9 |
Old Member
56
Rep 94
The difference is 1" , if you have the exhaust for the stock diffuser you can just slide the tips back 5/8" and it will fit the M diffuser just fine.
